which combo woudl you recommend
Old Aug 3, 2005 | 08:44 PM
IntegraTypeR's Avatar
Default which combo woudl you recommend
well i bought Manley Turbo tuff rods for my b16a engine and dont know which to choose from these two piston brands:
*Arias
*CP
well both are good but dont know which is the best for my application....where i live (overseas) temp here is around 80-114 F so i need good pistons that can take the heat even with a good tune and oh what should be my piston seals tolerance be at? my pistons will be 83mm and 9.0:1 compression ratio!
thanks in advance guys,
Km
Old Aug 3, 2005 | 08:48 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: which combo woudl you recommend (IntegraTypeR)
cp, nothing else
Old Aug 3, 2005 | 08:54 PM
Default Re: which combo woudl you recommend (wantboost)
any idea of seal tolrance here? and pricing difference? cause i heard some poeple say arais are more expsneive then CP and even heard the other way around! so which is true?
Old Aug 3, 2005 | 10:05 PM
lucidvtec's Avatar
what about JE
Old Aug 3, 2005 | 10:12 PM
MidShipCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">cp, nothing else</TD></TR></TABLE>
Arias are just as good I dont know how can we say its better wantboost ?
Default Re: (lucidvtec)
the garage am doing the build only deals with CP and Arias pistons
Old Aug 3, 2005 | 10:15 PM
Default Re: which combo woudl you recommend (MidShipCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">
Arias are just as good I dont know how can we say its better wantboost ?</TD></TR></TABLE>
well i know both are good, but as i mentioned where i live temp reaches 80-114 F (in other words thats really HOT) and i read on here that Arais pistons are meant to be for race use and they have a habbit of expanding so if thats true then Arias pistons arent good for me! i just clarification if CP pistons are good be better in my case or not?
Old Aug 5, 2005 | 04:11 AM
bump
Old Aug 5, 2005 | 04:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraTypeR &raquo;</TD></TR><TR><TD CLASS="quote">well i know both are good, but as i mentioned where i live temp reaches 80-114 F (in other words thats really HOT) and i read on here that Arais pistons are meant to be for race use and they have a habbit of expanding so if thats true then Arias pistons arent good for me! i just clarification if CP pistons are good be better in my case or not?</TD></TR></TABLE>
What the hell? there both made out of the same material.....
Anyways wiseco has there own forging plant, so I'm with them based on comparision by IBSPEC.
Old Aug 5, 2005 | 05:38 AM
Anyways wiseco has there own forging plant, so I'm with them based on comparision by IBSPEC.</TD></TR></TABLE>
are you telling me that both CP and Arias are bad or good? and is the expanding problem i read about Arias is nothing but clearance installed problem?
RICO_
Honda Civic (2006 - 2015)
Oct 5, 2007 04:30 PM
1fastEK9
May 11, 2007 09:14 AM
t57b18
Jan 28, 2006 05:32 PM
hondaapi
Dec 7, 2004 10:21 AM
hondaapi
Nov 24, 2004 07:25 AM
