d16y7 w/50shot compression results
Just tested the compression on my 97 d16y7
# 2,3,& 4 were 155~160 but #1 was 130...
I put a little oil and checked again and it was the same. 5 tries, all 130~133ish
I have ran about 2 1/5 bottles w/ the 50 shot nossle. fuel pressure was bumped up about 5 psi @ idle before adding the NOS kit.
How bad is this?
Is #1 notorious for going lean due to the poor design of the d16y7 intake mani?
How bad is this?
Re: d16y7 w/50shot compression results (97GSR Hatch)
If the comp didn't come up with oil in the cyl your problem is North of the rings. Most likely a valve sealing issue and most likely not nitrous related unless you ran the poor thing *** lean and cooked an exhaust valve a lil.
Re: d16y7 w/50shot compression results (Phase Change Racing)
I only put about 1/2 a teaspoon of 20w in... I've never done a valve job on the motor either.
are the numbers low for the rest of the cylindars?
I'm supprised that my 8:5:1 comp 2jz has about the same compression as the 3 good cyls' in my honda
I don't have too much Honda experience but most of the DOHC engines I have worked on squeeze out between 180-210. Some of the oddballs like the GM Quad Four will squeeze as high as 240.
The 155-160 does seem a bit low. How many miles are on this thing? Did you do the test after running it while it was warm?
Tested while warm 90 deg out w/ 100 % humidity Was at WOT, w/ 15 amp igintion fuse pulled, all plugs removed, 5 cranks per cyl. went up to like 8 trying to squeeze a few more out of #1. like 104kmi I belive on the odo. I've only sprayed like 23lbs of n20 through the setup over 30kmi.
Somthing may be up w/ the guage as the high 155's is all my supra and the civic have produced. but numerous attempts, cleaned around where it threaded in, put a bead of oil around the gasget on the comp checks threaded bit..
Any info appreciated! Thanks in advance
-James
-James
Compression tests can often be misleading. They do provide useful info but take it for what it is. The best way to determine sealing problems is by doing a leakdown test on all 4 holes.
It sounds like you did your comp test right so like I said before, i'd put my money on a valve sealing problem in that hole.
considering compression on a single cam will yeild low numbers anyway. compression is only around 9 something and the motor is not very new...
Re: d16y7 w/50shot compression results (cubish)
9 something? You mean 90 something? Either you have a paperweight for an engine or you have no idea how to do a compression test?
Haccordclub
05-21-2007 08:08 AM
Jet Black
12
06-08-2004 08:05 PM
