downpipe question
Old Aug 1, 2005 | 11:19 AM
98_4drCivic's Avatar
Default downpipe question
where is the best place to find flanges that will fit my turbo. i plan to make my own downpipe, but i am not sure where i can get the flange. it is a T3 from a saab, .54 trim. it is a 3 bolt flange. thank you
Old Aug 2, 2005 | 01:02 PM
Default Re: downpipe question (98_4drCivic)
anyone?
Old Aug 2, 2005 | 07:48 PM
PrettyLude's Avatar
atpturbo.com
Old Aug 2, 2005 | 08:00 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (PrettyLude)
^what he said, or bmcrace on here if all else fails
Old Aug 2, 2005 | 08:07 PM
Default Re: (wantboost)
alright, i figured out what im going to have to do...since i am staying internally wastegated for now, i have to keep the stock cast piece coming out of the turbo, and i cant use a 5 bolt flange...so im just going to use a regular 3 hole exhaust flange, unless there is a cheap and easy way to run an external wastegate on an hf manifold.....? i dont think it is possible to run and ext. wastegate on an hf man. unless you put the wastegate on the adapter plate? i dunno, ill figure it out. thank you for your replies
fabmaster
Feb 22, 2011 07:01 AM
Turbocivic94
Welding / Fabrication
May 22, 2009 04:56 PM
rhdune16
May 9, 2006 04:15 AM
J337_UNIT
Feb 17, 2004 09:41 PM
