ODB2 turbo cars, CAT help
Old 07-31-2005, 10:07 AM
freakie's Avatar
Default ODB2 turbo cars, CAT help
Hi guys
Recently changed my exhaust on my ITR and the second sensor that sits in the stock Cat was removed. After this removal (changed to an aftermarket unit), the cat light came up on the dash.
I believe the lgith comes up because the new exhaust does not have a port for the second sensor to plug into. IE I no longer run the secondary sensor.
Just posting to get a feel for what people have done to overcome this problem.
Also just as a matter of opinion, does anyone know what volts are sent to the sensor and what returns to the ECU when the sensor is detecting a proper AF? Im thinking of simply buying a plgu that fits into the stock Honda plug, and running some wire and putting in a few resistors to get the right return voltage to the ecu.
Thoughts or ideas are appreciated.
Old 07-31-2005, 10:12 AM
Who is Mr Robot?
wantboost's Avatar
Default Re: ODB2 turbo cars, CAT help (freakie)
just buy an o2 simulator.... also what are you running for fuel management? generally only a stock (like 100% stock) will throw a cel
SlowB16si's Avatar
Cant you put in a o2 bung in the cat or exhuast? Just get a bung and put the o2 sensor back in
Old 07-31-2005, 10:16 AM
freakie's Avatar
Default Re: ODB2 turbo cars, CAT help (SlowB16si)
sorry guys, im making it abit unclear, the ecu is fine, sorry for the confusion.
Im trying to get rid of the cat light that comes up on the cluster
Old 07-31-2005, 10:17 AM
Who is Mr Robot?
wantboost's Avatar
well, you could pull the cluster out and remove the bulb... but last time i checked they only had a check engine light, not an actual "cat" light. are you na or turbo? what are you using for fuel management?
Old 07-31-2005, 10:19 AM
freakie's Avatar
Default Re: ODB2 turbo cars, CAT help (wantboost)
im turbo now, and its a cat light. Its a jdm itr cluster
Old 07-31-2005, 10:35 AM
Who is Mr Robot?
wantboost's Avatar
hmm, well what are you using for fuel management?
Old 07-31-2005, 10:48 AM
rmcdaniels's Avatar
Why not just buy a good high-flow cat with a mid-bed O2 bung for your back O2 sensor. I got one from Carsound for about $70 and it worked great with my OBD2, plus the car made a bunch of power.
Old 07-31-2005, 01:42 PM
beepy's Avatar
Default Re: ODB2 turbo cars, CAT help (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">Why not just buy a good high-flow cat with a mid-bed O2 bung for your back O2 sensor. I got one from Carsound for about $70 and it worked great with my OBD2, plus the car made a bunch of power.</TD></TR></TABLE>
Werd. Carsound Magnaflow 94000 series cat. Come in up to 3" and you can get them with the RO2S bung already installed. I have no CEL and pass emmissions easily.
Old 07-31-2005, 06:43 PM
scttydb411's Avatar
convert to obd1 and use uber, crome, or hondata...tune to your hearts content.
Old 08-01-2005, 04:10 AM
freakie's Avatar
Default Re: (scttydb411)
ah, thanks for the help gents, i already have a cat and dont want to buy another, was just thinking of a way to "fool" the light, but giving the supplied resistance to the wires.
sounds like ill just have to drill into the exhaust and plug in a new sensor. thanks for the help
98GSR-Turbo
03-11-2008 03:29 PM
pumpkyn
01-30-2006 11:59 PM
sfgiants11
06-05-2005 07:22 AM
cubism
Welding / Fabrication
12-01-2004 10:39 AM
Etylorcen
10-25-2001 07:31 AM
Quick Reply: ODB2 turbo cars, CAT help
