wilding bucking on p72 s200b hondata from 2k - 4.5k rpms?
p72
hondata s200b
built b16
880 injectors
any idea what the bucking is caused by? also cant connect to the hondata at the tuner for a second tune, the car would just stall out when he tried to connect to it..... any ideas honda-tech? thanks in advance
hondata s200b
built b16
880 injectors
1 you ecu is screwed up or the solder is screwed...get someone new to tune the car
a shitty tps
shitty map sensor
to rich to lean tune
ignition problem
a shitty tps
shitty map sensor
ignition problem
Re: (D@nnY)
ummm I don't know off hand about the dying when you connect. As for the bucking, I can almost say 100% that you part throttle has not been tuned has it? If not, then that is definitely it. The bucking is usually really lean spots. The basemaps are terrible for part throttle and there is basically always bucking in between thsoe RPMs. And generally around 10" of vaccum is the worst I have found.
Re: (Dunc)
vaccum is good at 18inches at idle.... any other ideas? the TPS checked out and the map sensor is a 3bar.... checked all the connections at the ECU, all passes
Re: (BlueShadow)
timing is at 16, yes i tried running it at 18 and 19 no differences actually if anything made it worse
Who is Mr Robot?
Re: (importboi22)
its just a problem with hondata, ive heard of a lot of people having this problem, no matter what the timing is set at and how well it is tuned
Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">its just a problem with hondata, ive heard of a lot of people having this problem, no matter what the timing is set at and how well it is tuned</TD></TR></TABLE>
Thats not true...theres something wrong with the car or with the tune
Re: (wantboost)
i thought this problem was fixed a long time ago by the updated software they came out with?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importboi22 »</TD></TR><TR><TD CLASS="quote">timing is at 16, yes i tried running it at 18 and 19 no differences actually if anything made it worse</TD></TR></TABLE>
so your just playing around with the timing w/o any way to justify it? I wouldn't just change the base timing, because it throws off your ENTIRE tune then.....could lead to a failed motor.
And is the bucking at all throttle positions? I used to have bucking issues at 0psi, and 0 vaccuum....turned out it was the 02 sensor was fuckeD
Re: (m R g S r)
i tuned it back down to 16, i have even tried running 14 and 13 with no luck...... it bucks at any input 5% - 100%
Re: (importboi22)
get the dataloging on there and check the sensor readings...it sounds like a tps or fuel tuning problem .... It can also be bad plugs or a bad distributor
Re: wilding bucking on p72 s200b hondata from 2k - 4.5k rpms? (importboi22)
its not the EMS man...its your tune. Trust me go get it street tuned by a reputable tuner. Every person that comes to the shop has the exact same problem with bucking. Simply put, Hondata basemaps suck in vaccum. They are way way way lean in spots in vaccum (usually high vaccum, but everywhere in vaccum). This is what causes the bucking. Get that fixed and report back...I'd be willing to put money down that the bucking will go away.
Also check to make sure the red light on the S200 (blue box) is solid before you try doing anything...is it solid?
Re: wilding bucking on p72 s200b hondata from 2k - 4.5k rpms? (Dunc)
it is solid but when you try connecting the datalogger or anything else for it to tune the hondata will not connect and the car dies!
