bad stutter/backfire
Old Aug 1, 2005 | 02:48 PM
b18cEF9's Avatar
Default bad stutter/backfire
my car has started to stutter/backfire real bad in the last couple days, and ONLY in the 4-4700rpm range in every gear, cant figure out what the hell the problem is. Runing uberdata on a b18c1, 450 dsm, t3 turbo. any help would be appreciated, me and my buddies cant figure out why its doing this
Old Aug 1, 2005 | 03:44 PM
WhoDoYouThink's Avatar
Default Re: bad stutter/backfire (b18cEF9)
MAYBE CHECK YOUR TIMING. OR THE CHIP YOU HAVE COULD BE BAD. GOOD LUCK FIXING THAT.
Old Aug 1, 2005 | 06:02 PM
Hump-Free's Avatar
It might be ou distribatur. mine did that same thing exepct it was 3200 - 3500 RPM's
Old Aug 1, 2005 | 07:12 PM
ryan89crx's Avatar
Default Re: (Hump-Free)
ill try and check and see if the distro is grounding out to somthin, thanks fellas
Old Aug 1, 2005 | 11:48 PM
Eluzion's Avatar
I'm not sure about the backfire but I've had cases where stuttering in a certain RPM range was caused by spark plug wires. Might want to try swapping out with a friend to see if it fixes the problem. Good luck.
Old Aug 1, 2005 | 11:57 PM
steelies's Avatar
I'd be interested in hearing some more opinion.
I've run into the same problem. b18b, 450 dsm injectors, uber, all that
Old Aug 2, 2005 | 02:38 AM
adseguy's Avatar
Default Re: bad stutter/backfire (steelies)
When was your last tune done? You have to realize that every engine is created EXACTLY the same of the factory floor, but over time the engine will crack and warp here and there so VE and the way the engine breathes will change over time. That's why factory fuel and ignition maps are conservative. If you tuned over a year ago go tune again. What might have happened is that your engine may have started breathing a little differently and you now need a new partial throttle tune that's all. Weather effects things as well if you use Hondata/Uber/Crome.
I'm only mentioning this ^^ after you've done all the basic procedures like ignition and fuel fixups.
Old Aug 2, 2005 | 05:29 PM
ryan89crx's Avatar
we did a little messing with uber, and apparently on the StockGSR bin, vtec is set at 4100 rpms. raised it up to 5200, problem fixed. smooth transition now
decon
Nov 11, 2012 10:55 AM
V3locity
Dec 21, 2009 05:52 PM
roachsboosted16
Dec 9, 2007 01:25 PM
neEven
May 3, 2005 10:17 AM
freeplay
Oct 23, 2002 08:18 PM
