dyno graph of h22 with sc63 turbo
Re: my dyno graph of h22 with sc63 turbo (11seclude)
nice whats the AR on the hotside , that 63 deffn can make alot more power if your block is ready to handle it
I live under a rock
ONLY 5hrs? jeff can crank out stuff WAYY faster than that...... were you having troubles with something?? you should be able to crack 550 at least with a proper setup and that turbo
EDIT: just noticed you said JAMES evans.......
Re: (DLB1994)
The torque drops fast i know but with more boost i think it will hold alot longer trough the powerband. as far as et goes i dont know because i still need to get my DR from the shop. but i guess i should be in the mid to low 13s or if lucky high 11s i hope.
