low idle
Old Aug 4, 2005 | 07:39 AM
budget's Avatar
Default low idle
idle is set at 1000rpm with hondata but when i start to slow down at a light and come to a complete stop the idle will drop to the point its about to stall out. then from there it'll adle at like 4-500
Old Aug 6, 2005 | 09:08 AM
budget's Avatar
Default Re: low idle (suxway)
Old Aug 15, 2005 | 03:04 PM
Sohc Driver's Avatar
bump
Old Aug 15, 2005 | 04:48 PM
budget's Avatar
Default Re: low idle (Sohc Driver)
Old Aug 29, 2005 | 04:29 PM
Special B's Avatar
bump
Old Aug 29, 2005 | 10:32 PM
turtle-eg's Avatar
Bump... cuz my car does the same thing.... haven't figured out why.
Try to turn on the headlights when the rpms drop... this usually brings my revs back up to a 1000 or so.
Old Aug 29, 2005 | 10:59 PM
Cray91's Avatar
start looking at what else is happening at the same time.
Are you at full operating temperature?
Do you get an CEL's?
Does downshifting change anything?
Just suggestions.
Old Aug 30, 2005 | 05:11 AM
mike1114's Avatar
Default Re: (Cray91)
check IACV
Old Aug 30, 2005 | 10:28 PM
turtle-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cray91 &raquo;</TD></TR><TR><TD CLASS="quote">start looking at what else is happening at the same time.
Just suggestions.</TD></TR></TABLE>
On my car, it's does it a full operating temperature after crusing for a while. No CEL and downshifting doesn't matter cuz it's at idle.
Also tried a different IACV, same thing.... adjusted the idle bypass screw out, same thing.
Old Aug 30, 2005 | 11:23 PM
Retired's Avatar
WEST COAST
Check you map sensor voltage. Sensor is probally off. Might also have some crap in it.
rayray NOT shanaynay
Apr 26, 2007 04:19 AM
brad98_teg
Nov 10, 2006 01:30 PM
looxs
Nov 1, 2006 10:21 AM
-iLLuZioN-B18C1
Feb 21, 2004 03:14 PM
jspec rsx
15
Jan 11, 2004 08:10 AM
