PLX WIDEBAND QUESTION
Old Aug 4, 2005 | 11:11 PM
lucidvtec's Avatar
Default PLX WIDEBAND QUESTION
i got a plx m300...i wanna replace it with my stock o2 with this one...i'm also runnin a hondata s200wboost/dataloggin......so this plx has 4 wires coming off it red/black/white/grey...i know that the red and black are power and ground inputs and the other 2 wires grey and white are outputs...my question is can i hook up the wideband output to my ecu replacing the stock o2 and the other wire narrowband out from the plx to my autometer a/f ratio gauge...i think this should work because the gauge is a narrowband...i checked on plx's website and they make a converter for narrowband gauges that is on back order for ever....i emailed them numerous times about this and they would not answer to my dissapointment..i tried buyin the converter they said it was on backorder and automatically refunded my money...i would have waited...so do i need this converter box...or can i hook up the narrowband output from the plx m300 directly to my autometer gauge???......thx for any help
Old Aug 4, 2005 | 11:50 PM
lucidvtec's Avatar
bump for answer
Old Aug 5, 2005 | 12:34 AM
DutchEG6's Avatar
you connect the widesensor to the plx controller box..the controller box goes to the s200 from s200 it goes to the ecu
Old Aug 5, 2005 | 01:19 AM
lucidvtec's Avatar
i know how to hook it up to the ecu and hondata gets it from the ecu...my question about using the narrowband output from the plx m300 to a autometer a/f ratio gauge...will it work....has anybody ran this before
Old Aug 5, 2005 | 02:20 AM
cua0's Avatar
it should work, it's just sending a narrowband signal that the autometer gauge will interpret. it may not be accurate but it will work. (plx recommends a converter box to make the output accurate for the autometer gauges)
Old Aug 5, 2005 | 05:13 AM
93turbo16's Avatar
Default Re: (lucidvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucidvtec &raquo;</TD></TR><TR><TD CLASS="quote">i know how to hook it up to the ecu and hondata gets it from the ecu...my question about using the narrowband output from the plx m300 to a autometer a/f ratio gauge...will it work....has anybody ran this before</TD></TR></TABLE>
It will work just fine. But why not get a converter for like $45 and have your automemter display wideband readings.
Old Aug 5, 2005 | 05:39 AM
DaveF's Avatar
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">
It will work just fine. But why not get a converter for like $45 and have your automemter display wideband readings. </TD></TR></TABLE>
i thought the plx comes with its own digital display??
Old Aug 5, 2005 | 06:09 AM
93turbo16's Avatar
Default Re: (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
i thought the plx comes with its own digital display??</TD></TR></TABLE>
It does, but if you run the one without a display, you can run a converter off the wideband output so it will read on your autometer a/f gauge.
Old Aug 5, 2005 | 06:42 AM
ash.zero's Avatar
converter is definitely worth it. i'd wait for it.
Old Aug 5, 2005 | 08:49 AM
Pro-Am 1934's Avatar
Default Re: (ash.zero)
Here you go:
http://www.hondata.com/techplx.html
Also, a buddy of mine ordered a PLX M-300 from me at Streetrays.com. I looked on their website, and they sell the converter as well for like $38.00.
http://www.streetrays.com/cata.../2971
Jason
Old Aug 5, 2005 | 09:23 AM
King Tut33's Avatar
Default Re: (Pro-Am 1934)
I would keep looking till you find a vendor with the converter in stock. Somebody has to have them. I know I was planning on using one for my Defi A/F gauge.
Old Aug 5, 2005 | 09:32 AM
lucidvtec's Avatar
any body have this coverter...i need it i guess...and yes the m300 has a lcd display..i'm mountin mine in the glove box..i have a cluster bezel...with a autometer a/f ratio gauge..so i thought it would be nice to hook that up to the wideband...ya PLX wont give a date for the Converter to be released
TomCurllyFry
Engine Management and Tuning
Jul 20, 2012 05:12 PM
adamrich33
Mar 26, 2008 01:23 PM
Ls1 FD3s
Apr 14, 2005 11:25 PM
eg:R
Nov 3, 2003 03:58 PM
2.0L EK
Dec 2, 2002 07:18 PM
