Which Injectors Should I Choose?
Old Aug 3, 2005 | 06:16 PM
Integra_RS's Avatar
Default Which Injectors Should I Choose?
Im looking for injectors that will support up to 210-220 WHP.. I plan running around 180 WHP... but I would like the extra length open in-case I decide to turn up the boost. I was thinking 270cc's would be around that, what does everyone recomend? I also want it to be pretty much plug & play & dont have to mess with resistors & resistor packs. Thank you!
Old Aug 4, 2005 | 07:05 AM
Integra_RS's Avatar
I really need to know guys...
Old Aug 4, 2005 | 07:09 AM
non-VTEC's Avatar
Default Re: Which Injectors Should I Choose? (Integra_RS)
310's
Old Aug 4, 2005 | 07:25 AM
11psiTurboSI's Avatar
Default Re: Which Injectors Should I Choose? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">310's </TD></TR></TABLE>
or 440's
Old Aug 4, 2005 | 07:51 AM
tgreaves's Avatar
Default Re: Which Injectors Should I Choose? (11psiTurboSI)
I would get some DSM 440's.. They are pretty cheap and will do the power output that your looking for..
Old Aug 4, 2005 | 11:59 AM
Integra_RS's Avatar
anything over 310's would be overkill for my setup... ill be running dam rich as it is. FMU & a inline fuel pump.
How about 270cc's?
Old Aug 4, 2005 | 12:10 PM
tgreaves's Avatar
Default Re: (Integra_RS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_RS &raquo;</TD></TR><TR><TD CLASS="quote">anything over 310's would be overkill for my setup... ill be running dam rich as it is. FMU & a inline fuel pump.
How about 270cc's?</TD></TR></TABLE>
Didnt know you were using an fmu.. I would say to use stock injectors then with the fmu but I could be wrong, I dont deal with fmu's so I cant say for sure..
Old Aug 4, 2005 | 12:43 PM
dcp48's Avatar
people say stock injectors are good for 180-190 hp but when it comes to boost they say do not take it over 6 psi.. with the stock injectors. i mean theyre only 240cc so take it easy...
Old Aug 4, 2005 | 12:56 PM
4g63powered's Avatar
Default Re: Which Injectors Should I Choose? (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">I would get some DSM 440's.. They are pretty cheap and will do the power output that your looking for..</TD></TR></TABLE>
They're 450's, but you were close. IMO they're the best bang for the buck for you Honda guys, you should be able nab a set for ~$50
Old Aug 4, 2005 | 03:21 PM
KeyserSoze's Avatar
Default Re: Which Injectors Should I Choose? (4g63powered)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g63powered &raquo;</TD></TR><TR><TD CLASS="quote">
They're 450's, but you were close. IMO they're the best bang for the buck for you Honda guys, you should be able nab a set for ~$50</TD></TR></TABLE>
Agreed, get the dsm 450's and a resistor box. The box is really easy to install. Even I did it right! As for the fmu, I would seriously consider a bigger fuel pump, fpr and a decent management. The fmu just throws fuel in there without attempting to inject the correct afr. This is from my limited understanding anyway. Correct afr is essential.
Old Aug 4, 2005 | 05:00 PM
unusual71's Avatar
with a good computer, shouldn't the AFR be set correctly regardless of injector size? (of course you have to still be reasoable still)
dominate9
May 22, 2011 03:55 PM
RedneckRicer
Jul 22, 2008 10:41 AM
mahatma
Jun 11, 2007 10:23 AM
DA_JDM
38
Feb 20, 2007 01:40 PM
BoostedD15B7
Mar 19, 2004 10:15 PM
