Greddy Profec B Spec 2 owners check in
Tonight i do a 1 bar pull on a local highway (4th gear) So i get up to 5,000 hold it for a sec and get on it.
BTW build is lsvtec, sc61, cp .5 over 9.1's eagle rods etc so i take it to redline and i noticed i started to overheat a bit so i put it in neutral right away and coast to nearest offramp.
I notice my profec b at idle wasn't reading vaccume and then after i left the offramp didn't read boost, i'm really not too sure what just happened but i checked my connections and everything seems fine. Is this something common, not too sure what else i should describe but if anybody could help me out that'd be great
Re: Greddy Profec B Spec 2 owners check in (EGkid)
possibly a blown off vac line to the boost controller? since its not reading vaccume, for a second i thought i just blew off an IC pipe but it boosted fine, i'm alittle thrown off...
did you check the connection on the back of the unit itself to make sure that the line didnt blow off.
also do you have another boost gauge or do you just rely on the profec b? if you have one is that one reading vaccuum and boost?
Re: Greddy Profec B Spec 2 owners check in (B16Civic93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 »</TD></TR><TR><TD CLASS="quote">did you check the connection on the back of the unit itself to make sure that the line didnt blow off.
nevermind, last night when i tried looking for the problem it was pitch dark and i had a dinky *** flashlight, this morning before work i woke up and stupidly enough the vac line to the back of the IM that goes to the unit was blown off...doh
no i also have a defi d-gauge
turbotime
08-19-2006 09:54 PM
eg:R
04-25-2006 07:50 PM
