GT32 VS. GT28RS
Old Aug 4, 2005 | 07:29 AM
Talonspeed's Avatar
Default GT32 VS. GT28RS
Here is my setup B20 Vtec with 10.5:1 compression bolted up to a GSR transmission. Which turbo do you think will suit me best?? I plan on running about 10-14lbs of boost.
I think the disco will spool faster but fall off in the top end, while the Gt32 will do the opposite. BUT, I am not worried about lag that much cause of the high compression and aggressive gearing.
So what do you guys think?
Old Aug 4, 2005 | 07:55 AM
MrBond's Avatar
Default Re: GT32 VS. GT28RS (Talonspeed)
Isn't a split inlet housing (like the gt32) supposed to give huge gains in spoolup, given that you build a manifold to take advantage of this ?
I have heard you could expect as much as 25% earlier spoolup on a 6cyl, as well as more topend power. Dont know how this apply for a four cyl.
At least the gt32 has a much bigger turbine, and will give less backpressure and more hp up top, no doubt.
Old Aug 4, 2005 | 08:58 AM
Chip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Talonspeed &raquo;</TD></TR><TR><TD CLASS="quote">I am not worried about lag that much cause of the high compression</TD></TR></TABLE>
Compression doesn't do jack to help with spool up, so you might want to start thinking about lag more.
"10-14" pounds means nothing to us, because you could run 14 pounds of boost on a straight T3 turbo into your motor, but it isn't going to make nearly the power a GT32 will. Make a power goal, not a boost goal.
Old Aug 4, 2005 | 09:33 AM
JM Performance's Avatar
Default Re: GT32 VS. GT28RS (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip &raquo;</TD></TR><TR><TD CLASS="quote">
Compression doesn't do jack to help with spool up, so you might want to start thinking about lag more.</TD></TR></TABLE>
wrong.
talonspeed- depends on what power curve you want. it seems like you know what the option are, you just need to decide what you want your curve to look like.
Old Aug 4, 2005 | 09:49 AM
Chip's Avatar
Default Re: GT32 VS. GT28RS (00SilverLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00SilverLS &raquo;</TD></TR><TR><TD CLASS="quote">
wrong.
Prove it.
http://forums.evans-tuning.com...=1612
Ok, let me guess, you're going to tell me about your wealth of personal experience and how much compression owns? Right.
Trust me, I went ahead and built a 10.5:1 turbo motor because people like YOU told me high compression made the turbo spool up quick, only to be disapointed when I actually got it running.
Old Aug 4, 2005 | 11:21 AM
95GSRT's Avatar
If you are not worried about lag, go with the gt32, It still spools really fast.(don't you worry traction will still be an issue). The Gt32 is rated to ~520 hp.
Personally I find this turbo is bang for the buck and really under rated.
Old Aug 4, 2005 | 12:40 PM
blackeg's Avatar
Default Re: GT32 VS. GT28RS (95GSRT)
the 28rs will be getting out of efficency on 14 psi on a gsr motor i think.
the map for the gt32 is beautiful, much better than the gt30. see if you can get a gt32 with a .63 turbine a/r. should be perfect.
and 10.5:1 is kinda high, i hope you have a forged motor and good tuning in the works
Old Aug 4, 2005 | 01:24 PM
MidShipCivic's Avatar
Prove it.
Funny I do see more boost and power being made sooner... and <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> ''2.5" downpipe, 2.5" exhaust with an itr muffler (def. a restriction). About 20-25whp worth of power loss pretty much everywhere, with slower spool. We dropped the muffler and found out how restrictive. I can say that its the quiestest turbo car i have ever driven in and tuned.'' </TD></TR></TABLE>
This junk blocking up the exhaust can't show you considerable difference, this test isn't valid although does that show boost comming sooner.
Old Aug 4, 2005 | 01:38 PM
Chip's Avatar
Default Re: GT32 VS. GT28RS (MidShipCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">
Funny I do see more boost and power being made sooner... and</TD></TR></TABLE>
Funny, if you look at the boost curve you'd see boost comes on exactly the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">This junk blocking up the exhaust can't show you considerable difference, this test isn't valid although does that show boost comming sooner.
Yeah, and that junk blocking up the exhaust is blocking up the exhaust on the high compression and the low compression setup. A small exhaust wouldn't magically mask any huge spooling gains like what has been BS'ed around on here.
Even if that test were terrible, it's still better than any other nonexistant tests anyone else has showing how much *** high compression kicks.
Old Aug 4, 2005 | 01:46 PM
Except that I see boost comming sooner VERY early, then mimicking the curve at a higher evel than low compression line
Even if that test were terrible, it's still better than any other nonexistant tests anyone else has showing how much *** high compression kicks.</TD></TR></TABLE>
In conclusion the comparison was for turbo spool and theres an oem muffler plugging up the exhaust keeping the turbine spinning as freely as possible.
What kind of bs is that?
Old Aug 4, 2005 | 01:53 PM
duckmanEG's Avatar
Sexy Cheese Cake
what i read was more so saying that hes not worried about lag since he has compression and good gearing so the power b4 the turbo hits on will be fine with him. thats at least what i thought he was saying.
Old Aug 4, 2005 | 02:00 PM
Chip's Avatar
There's the pressure plot, I know it's pretty hard to see on boosted hybrid's site. The curves are, for all intents and purposes, exactly the same for spool up. The high comp one has a pinch more boost on top, which accounts for some of the extra horsepower. Now you tell me how this chart shows the high comp motor spooling quicker?
Old Aug 4, 2005 | 02:08 PM
Chip drop it... oem muffler.
Old Aug 4, 2005 | 02:21 PM
KeyserSoze's Avatar
Default Re: GT32 VS. GT28RS (duckmanEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duckmanEG &raquo;</TD></TR><TR><TD CLASS="quote">what i read was more so saying that hes not worried about lag since he has compression and good gearing so the power b4 the turbo hits on will be fine with him. thats at least what i thought he was saying.</TD></TR></TABLE>
Dito.
Old Aug 4, 2005 | 02:26 PM
Default Re: GT32 VS. GT28RS (KeyserSoze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">
Dito.
But seriously who worries about lag with a gt28rs ? It's needless to think about.
Old Aug 4, 2005 | 03:03 PM
KeyserSoze's Avatar
But seriously who worries about lag with a gt28rs ? It's needless to think about.</TD></TR></TABLE>
Don't get me wrong, I didn't say I'd be worried about the boost threshold, just said that I presumed that he meant that the boost threshold (cause that is what we are talking about right?) wasn't much of a concern because he had plenty in the motor (due to the high compression and gearing) at lower rpms. Nice run-on huh?
Old Aug 4, 2005 | 03:58 PM
99_GS-T's Avatar
You are comparing a 360 HP turbo to a 500+ HP turbo. They are two very different turbochargers. If you want a little more power then the GT28RS but are worried about lag, maybe think about a GT2871R, GT3071R or GT3076R.
Personally, I say get the biggest turbo that you can keep in boost after a full throttle shift just past your HP peak.
Old Aug 4, 2005 | 04:34 PM
integlspwr2k's Avatar
Default Re: GT32 VS. GT28RS (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">the 28rs will be getting out of efficency on 14 psi on a gsr motor i think.
and 10.5:1 is kinda high, i hope you have a forged motor and good tuning in the works</TD></TR></TABLE>
i have the same turbo. gt3255E
stock head stock block b16 on pump with 15psi..
330whp..
Old Aug 4, 2005 | 07:16 PM
blackeg's Avatar
Default Re: GT32 VS. GT28RS (integlspwr2k)
^^^^ see thats what im talking about. it looks like your power really comes in hard after 5k, which means that when you shift at redline, you will come back into gear right into the powerband, so lag shouldnt be an issue
Old Aug 4, 2005 | 08:14 PM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k &raquo;</TD></TR><TR><TD CLASS="quote">
330whp..
V nice #'s. All on stock engine, gives me good feelings about running 15psi on my setup.
Old Aug 4, 2005 | 11:08 PM
Talonspeed's Avatar
I dont want anything more than 350whp. This is going to be a daily driver, weekend warrior type car, lol.
My concers are that the Gt28RS will run out of breath on the top end. Stock cams have alot of overlap and I dont want reversion to kill my horse power.
I like the Gt32 because it is cheap!!! about $300-$400 less than a disco potato.
i want something that is going to pull all the way to redline without falling on its face and that is efficient running around 10-14psi.
Old Aug 5, 2005 | 06:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Talonspeed &raquo;</TD></TR><TR><TD CLASS="quote">I dont want anything more than 350whp. This is going to be a daily driver, weekend warrior type car, lol.
i want something that is going to pull all the way to redline without falling on its face and that is efficient running around 10-14psi.</TD></TR></TABLE>
your best bet would be the GT32 then..
the GT28RS is too small and will run out of steam in the top end.
milano2kdc2
Feb 16, 2006 07:41 PM
blackeg
May 19, 2005 12:32 PM
ramennoodles
Jan 6, 2005 02:02 PM
Boostage
Nov 7, 2004 11:20 AM
Charlie Moua
Jul 22, 2002 12:01 PM
