Does ne1 need an Eo1
Old Aug 3, 2005 | 08:57 PM
robtackett's Avatar
Default Does ne1 need an Eo1
I have a greddy Eo1 forsale for 400 shipped. In great shape.PROFEC E-01
GReddy's new super multi-tasker is the PRofec e-01 designed as a combination boost-controller, data display / logger and e-manage programmer. The e-01 can provide superior boost response, increased boost, warning meter functions, 3 channel data-logging and access to all the programming features provided with the latest e-manage support tool. Even when used as a boost controller only, the e-01 has features to smooth out the boost curve. With both an auto and manual setting for both external and actuator style wastegates, the new PRofec can alter its new compact, high capacity solenoid valve via various RPM ranges. The large LCD screen with green electro-luminescent backlighting is easy to see. Other standard features include two preset boost levels, a timed over-take boost and compatibility with our Remote Switching System. The data display can view 3 different data channels simultaneously such as boost, RPM or any other channel inputted by the e-manage. The data can be logged up for 3 hours on an SD card while also giving warning set points and peak and hold values. There is also a non-PRofec e-01 version that is only used for e-manage programming and datalogging. (Some features require optional harness to be accessed.)
PROFEC E-01
DESCRIPTION COLOR SPL NOTES PART# LIST$
PRofec E-01 silver 112x88mm boost controller / e-programmer (req. A/B USB cable) 15500207 $680.00
E-01 PRESS SENSOR HARNESS (com) to use e-01 press sensor for 15900543 $18.00
E-01 EXT SIGNAL HARNESS (signal) 2 pulse inputs, 2 linear inputs, 1 linear output 15900544
that 680 at bottom is MSRP I just cut and pasted from greddys page
Old Aug 3, 2005 | 08:59 PM
robtackett's Avatar
Default Re: Does ne1 need an Eo1 (robtackett)
reply at robtackett@yahoo.com please
Old Aug 3, 2005 | 09:00 PM
OMG B16's Avatar
Wrong place...
Killaogbobby
Mid-Atlantic (Sales)
Feb 13, 2009 03:13 PM
Tee Jay
Nov 17, 2007 05:05 PM
BodyKits NW
Aug 29, 2003 05:55 PM
Urban Business
Jun 13, 2003 12:31 PM
TheHater
Nov 19, 2002 05:29 PM
