Spec for arp studs in a ls/vtec
Old Aug 1, 2005 | 10:15 AM
sway892's Avatar
Default Spec for arp studs in a ls/vtec
I have the torque spec for a 94 GSR, but i'm using a ls/vtec with arp studs.
I want to know what the spec is for ls/vtec with arp studs. Already
searched, so if you don't have helpful comment don't write **** on here.
Old Aug 1, 2005 | 11:31 AM
B16Civic93's Avatar
Default Re: Spec for arp studs in a ls/vtec (sway892)
i would also like to know... so bump
Old Aug 1, 2005 | 12:33 PM
sway892's Avatar
Default Re: Spec for arp studs in a ls/vtec (B16Civic93)
I called ARP and they told me that the spec is 70 ft-lbs, the guy didn't
sound too sure. The spec I got from the integra manual was 64 ft-lbs for
94 and up integra. If anybody uses or used anthing different, tell us what
you used.
Old Aug 1, 2005 | 01:44 PM
Jared's Avatar
70ft/lbs with moly lube
Old Aug 1, 2005 | 05:20 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Spec for arp studs in a ls/vtec (Jared)
80ft lbs with ARP lube 70 with oil......
i alwys did mine to 72-74 never had a problem....
lsvSwagg
Oct 28, 2012 06:53 PM
techtuner
Northwest (Sales)
Mar 30, 2011 01:04 PM
jdmeeeeeeeeg
Jun 16, 2009 12:29 AM
ptsaurus
20
Jun 6, 2004 02:04 PM
ridnmyhonda
May 23, 2002 06:13 PM
