do u have to run water lines for gt30r turbo??
same as title. since the turbo came with it, is there a reason that you should run the lines. is it really recommended? will there be any cause of damage to turbo if water lines is not used.
alot of people run oil/water turbos without the water lines hooked up.
Sure it's not gonna last as long as if you used both,
but do you really plan on having that turbo for 100k miles??? I highly doubt it..
Re: (RacerXI)
i hooked both up on mine, i figure they set the center section up that way for a reason. i wouldnt chance not hooking them on a BB turbo.
Who is Mr Robot?
Re: (DontBlink)
you must run the water lines.... garrett turbos use dual steel ball-bearings... they expand with the high heat, the water lines must be used or the bearings will prematurely fail
can someone post where i can get the hardware to hook up the lines?? is it possible to run the lines to the radiator lines where the auto tranny lines from the radiator?
Re: (eg:R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg:R »</TD></TR><TR><TD CLASS="quote">can someone post where i can get the hardware to hook up the lines?? is it possible to run the lines to the radiator lines where the auto tranny lines from the radiator? </TD></TR></TABLE>
bump I am trying figure that out also
Who is Mr Robot?
Re: (LShatchie)
you can get the fittings for the turbo from atpturbo.com although they do want a pretty good bit for them
as for the water source, use the line that goes from the head to the throttle body
Re: (eg:R)
http://www.anplumbing.com
#984404 or #984004 in the required hose i.d. and fitting size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">you must run the water lines.... garrett turbos use dual steel ball-bearings... they expand with the high heat, the water lines must be used or the bearings will prematurely fail</TD></TR></TABLE>
exactly....people seem to be asking this question so much recently......
adding on to wantboost's response....a ball bearing turbo's center cartridge builds up a crap load of heat...the water coolant lines are 110% neccesarry to run this turbo properly to avoid problems later, like prematurely failing bearings.
