Fan not coming on
Old Aug 2, 2005 | 01:01 PM
Lucky_Smurf's Avatar
Default Fan not coming on
I replaced my stock radiator fan with a slimline fan. The fan came with the motor only no switch or anything. So I cut the wires to the stock clip and wired the clip onto the new fan thinking that the fan would just kick on when the stock one would. I know the wiring is good so I'm thinking it's got to be the wiring harness and some sensors are in the wrong position( I just put he motor back in). Any idea what particular sensors I should be looking at and what wires go into those sensors. I think I might have a few backwards.
Old Aug 2, 2005 | 02:06 PM
RacerXI's Avatar
Default Re: Fan not coming on (Lucky_Smurf)
What motor do you have? One problem I had with my car is I swapped the coolant temp & vtec plugs when I first put my motor in (b16) and the fan didn't come on b/c it couldn't tell it was even hot. Check your fuses and then try throwing 12v to it. HTH.
Old Aug 2, 2005 | 02:13 PM
porsche997dc2's Avatar
Default Re: Fan not coming on (RacerXI)
Just connect oem blue wire to slimfan's blue wire and black to black. The only time fan come on is when the engine is hot. If you have AC, then turn on the AC the fan will come on.
Old Aug 2, 2005 | 02:19 PM
Default Re: Fan not coming on (porsche997dc2)
It's a b18C fully built with a b16 head. I think I did switch the vtec and coolant plug.
Porsche997dc2
I did exaclty that blue to blue black to black and it is getting hot. Thanks though.
Corksil
Dec 9, 2009 06:56 PM
busted90accord
Apr 3, 2008 08:12 AM
fastlude69
Aug 4, 2005 02:03 AM
altoid
Aug 5, 2003 03:22 PM
Vitt1
Aug 19, 2001 06:49 AM
