Fastest spool turbo for GSR?
Old Aug 3, 2005 | 02:16 PM
kevin85193's Avatar
Default Fastest spool turbo for GSR?
I've been debating back and forth about the setup I want to get... and I just figured "go big or go home"
What turbo is the best for the fastest spool time on a GSR?
SC61
GT series?(which?)
I'm only looking to push 300hp untill ALOT later down the road build the engine...
daily driven/drag/some auto-x
Old Aug 3, 2005 | 02:24 PM
LaXcAt's Avatar
Default Re: Fastest spool turbo for GSR? (kevin85193)
gt28rs
Old Aug 3, 2005 | 02:29 PM
sqad_7's Avatar
Default Re: Fastest spool turbo for GSR? (LaXcAt)
SC61 wil do but the a GT30 has quicker spool and will keep it's breath up top
Old Aug 3, 2005 | 02:47 PM
JSpin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaXcAt &raquo;</TD></TR><TR><TD CLASS="quote">gt28rs</TD></TR></TABLE>
i'm with stupid
if you're seriously concerned about spool time, back away from the sc61, it's kind of a pig.
Old Aug 3, 2005 | 02:55 PM
kevino002's Avatar
Default Re: Fastest spool turbo for GSR? (JSpin)
for the power you are looking for I would go with a GT28rs, that thing will spool almost instant and will make 300hp.
Old Aug 3, 2005 | 03:14 PM
kevin85193's Avatar
Default Re: Fastest spool turbo for GSR? (kevino002)
okay, thanks alot guys!
Old Aug 3, 2005 | 03:21 PM
SHystrdyGSRtdy's Avatar
Default Re: Fastest spool turbo for GSR? (sqad_7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sqad_7 &raquo;</TD></TR><TR><TD CLASS="quote">SC61 wil do but the a GT30 has quicker spool and will keep it's breath up top</TD></TR></TABLE>
sc61 is far from a fast spooling turbo.
Old Aug 3, 2005 | 03:23 PM
kevin85193's Avatar
Default Re: Fastest spool turbo for GSR? (SHystrdyGSRtdy)
k, the question is.. cheapest place to buy the gt28rs?
Old Aug 3, 2005 | 03:35 PM
kevino002's Avatar
what manifold do you have, if you are going to to with a T3 housing you can find them on here for a good price.
Old Aug 3, 2005 | 05:49 PM
sqad_7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">
sc61 is far from a fast spooling turbo.</TD></TR></TABLE>
i didn't say the sc61 was a fast spooling turbo. I said it will do but the GT would be quicker spool wise and hold it's on up top.
Old Aug 3, 2005 | 06:00 PM
turbosnatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevin85193 &raquo;</TD></TR><TR><TD CLASS="quote">k, the question is.. cheapest place to buy the gt28rs?</TD></TR></TABLE>
camp1320.com
he's the man
Old Aug 3, 2005 | 06:14 PM
Tooned's Avatar
Default Re: Fastest spool turbo for GSR? (turbosnatch)
I agree gt29
Old Aug 3, 2005 | 06:15 PM
Tooned's Avatar
Default Re: Fastest spool turbo for GSR? (Tooned)
sorry gt28
Old Aug 3, 2005 | 06:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sqad_7 &raquo;</TD></TR><TR><TD CLASS="quote">i didn't say the sc61 was a fast spooling turbo. I said it will do but the GT would be quicker spool wise and hold it's on up top.</TD></TR></TABLE>
but that wasn't the question, putting sc61 as an option of "fastest spool turbo for GSR", just doesn't work
anyhow, yes the sc61 WILL DO, but it sure won't be the fastest
Old Aug 3, 2005 | 08:01 PM
kevin85193's Avatar
actually looking at the gt2871
DUAL GT STEEL BALL BEARING CENTER SECTION
TURBINE SPECS: GT25
.86 a/r
76 TRIM 54mm GT series wheel
COMPRESSOR SPECS: TO4b
.60 A/R HOUSING
71mm 56 trim wheel
Old Aug 3, 2005 | 09:55 PM
KrispyKreme's Avatar
this may be a little off topic, but dotn you have to run water cooling lines for the gt turbos?
Old Aug 3, 2005 | 09:58 PM
Default Re: Fastest spool turbo for GSR? (lshatch318)
not 100% sure but i think it's optional?
btw, do you have a budget?
Old Aug 3, 2005 | 10:07 PM
a1320addict's Avatar
yes water lines need to be run for gt series turbos
go with the disco potato
Old Aug 3, 2005 | 10:31 PM
project dc2's Avatar
Default Re: Fastest spool turbo for GSR? (yehiknowrite)
i got a GT2871RS . i hit 15 psi by 4300
Old Aug 4, 2005 | 12:11 AM
superfuji57's Avatar
I wish I would have went with a smaller turbo rather than the sc61 so long ago because of the slooowwww spool. Or better yet bore to 2.0 =\
Old Aug 4, 2005 | 04:45 AM
toolowsol's Avatar
Default Re: (superfuji57)
I've been running an SC34 on my b18c for a little over a year now, I'm very glad I didn't get any bigger of turbo! This is definatly the largest turbo you want to put on your b18c if you want a comfortable daily driver. My turbo starts to build boost around 2500rpms and is fully spooled to 8psi by 3500. If I were to do it all over again, I would get an even smaller turbo. btw I mostly use my car as a daily driver with some autoX.
Old Aug 4, 2005 | 07:54 AM
cuin9sec
Guest
Posts: n/a
sc61
Old Aug 4, 2005 | 09:00 AM
sqad_7's Avatar
Default Re: (t67civic)
my new choice is GT28rs for quick spool
SC61 for big numbers up top
Old Aug 4, 2005 | 02:39 PM
kevin85193's Avatar
Default Re: (sqad_7)
GT2871 is what im going to go with i believe
Old Aug 4, 2005 | 02:52 PM
Ben Huynh's Avatar
https://honda-tech.com/zerothread?id=1281669
