oil in charge pipe
Old Aug 4, 2005 | 05:08 PM
tony n.'s Avatar
Default oil in charge pipe
my friends si...he has a drag kit on there...the other day we look the charge pipe off on the hot side and there was oil in there....and theres oil on the intake side of the turbo...the car doest smoke or anything...can anyone tell me whats wrong with his turbo?
Tony
Old Aug 4, 2005 | 05:12 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: oil in charge pipe (boosted2cam)
Seals are gone.
Old Aug 4, 2005 | 05:28 PM
tony n.'s Avatar
Default Re: oil in charge pipe (boostincoupe)
even tho theres no smoke comin out from the exhasut?
Old Aug 4, 2005 | 05:42 PM
BlueSi2k's Avatar
yup, my first turbo came with bad seals and i had oil all in the i/c and piping...no smoking either. You will only smoke if the seals on the exhaust side are bad and it lets oil into the downpipe. I would get it fixed asap though since you run a much higher risk of detonation with oil in the combustion chamber.
Old Aug 4, 2005 | 08:02 PM
tony n.'s Avatar
Default Re: oil in charge pipe (BlueSi2k)
what causes this problem?
Old Aug 4, 2005 | 08:28 PM
..::91TEG-G2::..'s Avatar
normal wear and tear, heat, product malfunction..
Old Aug 5, 2005 | 09:57 PM
desiromeo812's Avatar
Default Re: oil in charge pipe (..::91TEG-G2::..)
i heard that ur suppose to have some oil on that side.. lik ei have some which is enuff to stain my finger but it doesnt drip oil or have hella oil in there.... i could b wrong
Old Aug 6, 2005 | 08:41 AM
Default Re: oil in charge pipe (desiromeo812)
i think i remember hearing something like that too. it was with my boys MK3.. but like you.. i could be wrong
Old Aug 6, 2005 | 09:15 AM
EJ1 wilcox's Avatar
No, there's not supposed to be any oil in the charge pipes, they should be dry... if there is any oil in them then the compressor seal is worn and leaking oil.
My compressor seal started leaking oil 6 months after I put the turbo on my car. There was no smoke or anything but when I took the lower charge pipes off there was oil all over them. Then I took my intercooler off and there was tons of oil in it.
There was also oil spewing out of my BOV when it would shift, which means the oil was getting all the way up into my intake manifold.
So, I did a semi-rebuild. I bought a turbo rebuild kit, took it apart and cleaned all the parts. Then used a new compressor seal and a few other new parts and put it all back together. I made sure to mark the compressor wheel in relation to the nut and turbine shaft so as to maintain the original balance.
Threw it back on my car and it's been boosting perfectly since then.
Oh, when I took my turbo apart, I found that it was MISSING an o-ring which was part of the compressor seal. I assume that was the problem, I bought the turbo from a place that is known for poor rebuilds.
Anyways, good luck getting it rebuilt or doing it yourself.
TomTomTuning
Honda S2000
32
Jul 5, 2006 06:16 AM
tvic
Sep 13, 2005 06:33 PM
djnikko
Aug 12, 2003 06:28 AM
dirtySOHC's
Apr 3, 2003 05:37 PM
intekragsr
Sep 25, 2002 03:35 PM
