block guard vs. sleeves
Old Aug 3, 2005 | 09:22 PM
sloweredcivic's Avatar
Default block guard vs. sleeves
i did a search but came up with no definate info.
i will be building a ls bottom end.
10 pounds street 18 or 22 on the weekend dragging
(not my daily driver)
will block guard hold or should i sleeve it
Old Aug 3, 2005 | 09:30 PM
Redwidow's Avatar
Default Re: block guard vs. sleeves (sloweredcivic)
I'd Sleeve it because More Boost is always fun...it seems that everyone always wants more.. so it helps in the long run
Old Aug 4, 2005 | 02:11 AM
Squirtle's Avatar
Hmmmmmmmmm! Sleeve it.
Old Aug 4, 2005 | 04:51 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (squirtle)
i plan on running around 20lbs on my 9:1 compression ls motor for dragging and shooting for 300whp daily driving
i believe the limiting factor is your setups capability, 400whp stock sleaves is common, if you want 500 plus id def go with sleaves
again its all in the tune of the car, even sleaved motors wont last long w/o a good tune
Old Aug 4, 2005 | 09:08 AM
Junglesnake's Avatar
For your hp goals sleeves are not needed at all nor is a blockguard.
Old Aug 5, 2005 | 10:13 AM
ok so blcok guard on a ls is good to 400 whp with a good tune 400 and up sleeve it. one other questions is there a difffernce in a b18a and a b18b bottom end. its going to be a ls vtec
Old Aug 5, 2005 | 10:31 AM
Default Re: (sloweredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweredcivic &raquo;</TD></TR><TR><TD CLASS="quote">ok so blcok guard on a ls is good to 400 whp with a good tune 400 and up sleeve it. one other questions is there a difffernce in a b18a and a b18b bottom end. its going to be a ls vtec</TD></TR></TABLE>
dont use a blockguard or anything for up to 400hp, stock sleaves are fine for 400, anyhthing 450 n up get sleaves
Old Aug 5, 2005 | 10:33 AM
Andrea's Avatar
Default Re: (coptzer)
No block guard and no sleeves. You can meet your power goals reliably without both.
Old Aug 5, 2005 | 03:05 PM
Darton Sleeves's Avatar
Default Re: (Andrea)
Sleeve it!!!
Old Aug 5, 2005 | 05:17 PM
mamaboy's Avatar
going to run the Z6 i have with a block guard. going to make a budget Z6 build running a GT28R. it's all up to the whp you wish to gain and turbo size.
Old Aug 5, 2005 | 05:35 PM
mrDFWmechanic's Avatar
you dont need to sleeve it or put a blockguard on it, just take it to a very reliable tuner and have him tune it to what you want.
Old Aug 5, 2005 | 06:21 PM
MooreBoost's Avatar
Default Re: (iROCKtheSOHC)
What are your power goals?
Old Aug 5, 2005 | 09:50 PM
ok let me ask this then
are there any disadvantages to blockguard with a goal of 400 whp.
Old Aug 5, 2005 | 09:54 PM
MooreBoost's Avatar
Overheating and improper installation.
Old Aug 6, 2005 | 06:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweredcivic &raquo;</TD></TR><TR><TD CLASS="quote">ok let me ask this then
are there any disadvantages to blockguard with a goal of 400 whp. </TD></TR></TABLE>
They are, plain and simple, a waste of money.
Old Aug 6, 2005 | 05:39 PM
MooreBoost's Avatar
Default Re: (Junglesnake)
They aren't a waste of money at all.
They just have to be installed correctly.
Old Aug 6, 2005 | 06:32 PM
carchitect's Avatar
I would recommed having it sleeved but I've run 24 psi on a stock block with a stacker head gasket (B18C5) and made over 400hp on it.
http://www.atsracing.net/nicks...R.htm
I tuned it and stopped tuning once we hit this mark. I could've easily gained more power. I was just very concerned about it comming apart with this much power but it lived for over 6 months until the manifold fell apart.
As every one mentions. Tuning is everything. It doesn't matter if its built or not a properly tuned engine is everything.
I would never run this much power in my engine w/o building it.
Joe.
Joe.
SOHCmaster's Avatar
block guards are hype.........True sleeves are your only chance. Thats just the way it is and the way it will always be...
You can chance 400+ on the stock sleeves, but wouldnt want to if I had the money to do it right.
Old Aug 6, 2005 | 07:30 PM
EnzoSpeed's Avatar
Default Re: (PK SPEED)
I would rather use nothing at all than use a blockguard. My SOHC has a $2k head with a $2k shortblock and I still wouldn't go near a blockguard.
Old Aug 8, 2005 | 07:31 PM
would there be any difference in a gsr bottom end. i mean it would be nice to not have to convert it to vtec
Old Aug 8, 2005 | 07:44 PM
ValleySyder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweredcivic &raquo;</TD></TR><TR><TD CLASS="quote">i did a search but came up with no definate info.
will block guard hold or should i sleeve it </TD></TR></TABLE>
weekend draggger or not u dont need sleeves unless u have money to throw down .. ive seen 610whp on stock sleeves. its all on your tuner to decide if its safe to run stock sleeves on high hp set up ..what is your horsepower goals
Old Aug 8, 2005 | 10:14 PM
G
sh!t happens.
Default Re: (Darton Sleeves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darton Sleeves &raquo;</TD></TR><TR><TD CLASS="quote">Sleeve it!!! </TD></TR></TABLE>
Old Aug 8, 2005 | 10:42 PM
Zakar's Avatar
they arent cheap.. if you dont expect the engine to see 500+ then dont do it..
also.. dont have your mind set on X psi daily x psi track.. your tuner will set you at the highest power level you can safely attain with your local pumpgas.. whatever psi it should be.. take his word for it
Old Aug 8, 2005 | 10:55 PM
careawholelot's Avatar
Default Re: (Zakar)
don't be a cheap *** do it right the first time and sleeve it, its not your daily so let the car sit for awhile, i made the mistake of not building my motor when i should have, now its costing more time and money when i shoulda done it all in one shot but i got greedy, u gotta have patience. i haven't drove my car since dec 2, 2004, but it's almost all done
Old Aug 11, 2005 | 05:38 PM
tobe1424's Avatar
Default Re: (careawholelot)
whats so bad about block guards why are most ppl against it...i think its way cheaper to put a block guard than to sleeve your block
