which tuning program to use?
Old Jul 30, 2007 | 07:03 PM
92hatch_cx-t's Avatar
Default which tuning program to use?
I want to tune my car but i dont really know what program to use. which one would you guys recommend from these: uberdata, crome or neptune. my car is a d16z6 turbo. i am using a t3 t4 turbo. tial external wastegate. 3 inch downpipe. i am thinking of boosting about 8-11 psi.... do i need a three bar map sensor? or can i use the stock one and do i need bigger injectors? any feedback will be greatly appreciated. Thanks
Old Jul 30, 2007 | 07:24 PM
Sr420Det's Avatar
I would say you need bigger injectors and a map sensor. I think the factory ms is good to like 10 psi but id run a little less. The d series are only good for 8lbs with stock internals. I really have no experiance with any programs you mentioned, somone else should be able to help you out.
Old Jul 30, 2007 | 07:29 PM
Default Re: (Sr420Det)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sr420Det &raquo;</TD></TR><TR><TD CLASS="quote">I would say you need bigger injectors and a map sensor. I think the factory ms is good to like 10 psi but id run a little less. The d series are only good for 8lbs with stock internals. I really have no experiance with any programs you mentioned, somone else should be able to help you out.</TD></TR></TABLE>
like what size injectors do u recommend? and what map sensor? yeah its my daily driver and i dont really want that much boost.
Old Jul 30, 2007 | 07:36 PM
Schister66's Avatar
Man U FTW
i've had good luck w/ Crome over the past couple years....i'd check it out. Neptune is going to be better, but you're also going to pay for it....
Old Jul 30, 2007 | 07:49 PM
blackeg's Avatar
Default Re: (Schister66)
ive used uberdata for abbout 4 years. it got the jobdone but was kinda annoying at times. ive since been tuned on neptune and the car runs 100x smoother and better.
Topdawgg's Avatar
uberdata used to be good, now I use crome, and then Crome Pro if you wanna spend alittle money...
Old Jul 30, 2007 | 08:44 PM
ndogg's Avatar
Default Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">uberdata used to be good, now I use crome, and then Crome Pro if you wanna spend alittle money...</TD></TR></TABLE>
agreed.
450's should meet your needs, but it never hurts to go larger (550, 650, 750) thus leaving more room to grow. if you get larger than that, it take more skill to get a good idle but still possible.
stock map sensor will work but if you are running 11psi you will be at the end of the maps. also you need a little overhead to run a reliable boost cut. running the stocker at 11psi will not allow this.
Old Jul 30, 2007 | 10:27 PM
mtber's Avatar
Default Re: which tuning program to use? (92hatch_cx-t)
If you want to be a baller, go with neptune rtp or hondata s300
Old Jul 31, 2007 | 06:31 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sr420Det &raquo;</TD></TR><TR><TD CLASS="quote">I would say you need bigger injectors and a map sensor. I think the factory ms is good to like 10 psi but id run a little less. The d series are only good for 230whp with stock internals. I really have no experiance with any programs you mentioned, somone else should be able to help you out.</TD></TR></TABLE>
Fixed it for you - psi has very little to do with what a stock D-series can do.
Old Jul 31, 2007 | 09:00 AM
MeanGreenMachine's Avatar
i chose neptune rtp to run in my setup
Old Jul 31, 2007 | 10:28 AM
Schister66's Avatar
Man U FTW
Default Re: (Joseph Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">
Fixed it for you - psi has very little to do with what a stock D-series can do. </TD></TR></TABLE>
much better after the quote
Old Jul 31, 2007 | 11:35 AM
thanks to all of you guys for your input....i might use crome or neptune then... im definetly getting new injectors and possibly map sensor....
Old Jul 31, 2007 | 01:38 PM
PrecisionH23a's Avatar
Default Re: (92hatch_cx-t)
I would go with neptune over crome. The s300 is also very nice if you've looked into the hondata systems.
Old Jul 31, 2007 | 07:37 PM
Default Re: (PrecisionH23a)
most of my frends have used neptune and s300 but i think im gonna use neptune.
any one in the bay area has ever tuned with black trax performance? are they good?
well as u can see im totally new to turbo.... so what type of spark plugs would you guys recommend.... most people ive heard use NGKs but dont know what type.
thanks
Old Aug 1, 2007 | 04:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatch_cx-t &raquo;</TD></TR><TR><TD CLASS="quote">most of my frends have used neptune and s300 but i think im gonna use neptune.
thanks</TD></TR></TABLE>
blacktrax just recently was added to the neptune authorized dealers/tuners.
if you look on the http://www.hrtuning.com website and look at the list of the dealers, most if not all are well known reputable tuners. to ME that says alot about the creator of neptune and that he has good taste in choosing the right person to tune neptune. and the neptune rtp is tunable by anyone, even the average joe if your willing to learn the software........
Old Aug 1, 2007 | 04:39 AM
morgan@synapse motorsport's Avatar
Default Re: (MeanGreenMachine)
Neptune or S300, can't go wrong with either
Old Aug 1, 2007 | 08:03 AM
Schister66's Avatar
Man U FTW
I know that when i go back for another tune (hopefully next summer), i'm making the switch from Crome to Neptune
i haven't had any problems with Crome at all, but eventually one needs to upgrade
Old Aug 1, 2007 | 07:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine &raquo;</TD></TR><TR><TD CLASS="quote">
if you look on the http://www.hrtuning.com website and look at the list of the dealers, most if not all are well known reputable tuners. to ME that says alot about the creator of neptune and that he has good taste in choosing the right person to tune neptune. and the neptune rtp is tunable by anyone, even the average joe if your willing to learn the software........</TD></TR></TABLE>
yeah definetely using neptune..... yeah thats how i found them..... thats the only tuner i know that will tune neptune because i looked in their website..... thanks
Old Aug 2, 2007 | 04:14 AM
yeah definetely using neptune..... yeah thats how i found them..... thats the only tuner i know that will tune neptune because i looked in their website..... thanks</TD></TR></TABLE>
i believe there was another neptune tuner guy in CA, andy chan ring a bell?
i dont see him listed on the hrtuning website anymore but when i asked, i was told he was busy tuning other vehicles on a another system and could come back to tuning neptune whenever he chose to...
Old Aug 2, 2007 | 06:39 AM
Any of the Honduh ECU options = cake.
Old Aug 2, 2007 | 05:24 PM
i dont see him listed on the hrtuning website anymore but when i asked, i was told he was busy tuning other vehicles on a another system and could come back to tuning neptune whenever he chose to...</TD></TR></TABLE>
yeah ive heard of him but like you said he is not in the list anymore so i dont know what happened..... i think he tuned in san francisco.... right?
Old Aug 2, 2007 | 05:36 PM
yeah ive heard of him but like you said he is not in the list anymore so i dont know what happened..... i think he tuned in san francisco.... right?</TD></TR></TABLE>
yes i believe that is correct, he is in san fran.
Old Aug 3, 2007 | 04:07 PM
well i need someone that sells it and tunes it.....
Old Aug 3, 2007 | 05:17 PM
nowtype's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">Any of the Honduh ECU options = cake.</TD></TR></TABLE>
Seriously. You can get a car running pretty solid on Uberdata 1.2. Any of the current options are fine. They all come with their strengths and weaknesses. It's all about picking the one that has the most strengths that benefit you and the least amount of weaknesses that hurt you. Pretty basic pro/con list will work wonders.
Old Aug 3, 2007 | 05:46 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: which tuning program to use? (mtber)
3 bar to properly use the boost cut, bigger injectors, and i vote s300. NO CHIPS w00t!
