Throttle Postion Sensor?? HELP!
Old Jul 25, 2007 | 10:25 AM
jarven093's Avatar
Default Throttle Postion Sensor?? HELP!
Could a bad throttle postion sensor cause the motor to idle from 500 rpms to 1200 rpms and back to 500 and so forth? i have checked for vacc. leaks and found nothing..... i have a VAFC-2 ( i know gay, gunna get chipped ecu soon ) and when the car starts to flucuate in idle if i get the rpms up a little then it stops like if i hold it at 2000rpms but if i watch the vafc-2 its says the rpms are at 2000 but if i countinue to hold it there at say 2% throttle at 2000 rpms the 2% throttle will stay the same but the rpms will drop slowly tell it gets back down to 500 rpms and begins to idle from 500 to 1200 (back and forth) then if i let off the throttle it will kill the motor?? dose that mean TPS is bad? any help thanks
Old Jul 25, 2007 | 10:41 AM
Astig's Avatar
Default Re: Throttle Postion Sensor?? HELP! (jarven093)
Did you recently put in a new motor or change any plugs around? They might be mixed up.
Old Jul 25, 2007 | 10:50 AM
jarven093's Avatar
Default Re: Throttle Postion Sensor?? HELP! (Astig)
Its a D16z6 and the problem started before i went to turbo setup ... the motor was basically stock like header MSD with external coil And it happend right after i put on a new clutch and lightend flywheel ( 8.5lbs )
Old Jul 25, 2007 | 11:22 AM
RC000E's Avatar
With the motor running pull the charge pipe so you can see the inner bore of the throttle body. With the motor at operating temp, put your finger over that lower left hole inside the tb. If that is pulling vacuum with the motor warm, then the thermo valve beneath the tb is the problem. It's hanging opened because the seat is probably unscrewed.
Old Jul 25, 2007 | 01:05 PM
jarven093's Avatar
Default Re: Throttle Postion Sensor?? HELP! (RC000E)
ok just did that and it is pulling vacc. pretty good suck too can leave a hicky.... how do i fix this????
Old Jul 25, 2007 | 04:54 PM
b16a4's Avatar
bump
Old Jul 27, 2007 | 03:24 PM
jarven093's Avatar
Default Re: Throttle Postion Sensor?? HELP! (b16a4)
ok got it cleaned out and screw all the way in and idle problem GONE!!!!! yeah thanks for the help! so happy
Old Jul 27, 2007 | 04:49 PM
b16a4's Avatar
i dont have the thermo valve beneath the tb
import-tooner
Jul 19, 2013 06:39 AM
skylude23
Jun 29, 2006 07:22 AM
Hyaboosta
Mar 10, 2005 09:36 PM
gavhowe
Apr 30, 2003 03:10 AM
soHybridized
Mar 13, 2002 10:22 AM
