spark plugs for 400-500 hp
what spark plugs are u guys using for 400-500hp cars. how much colder should they be. they are going in an h22. if someone could give me a part number for the proper nkg plugs that would be great. thanks!
Re: (92gs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92gs »</TD></TR><TR><TD CLASS="quote">i use ngk #9 600hp+ here with no problems..gap them at .028</TD></TR></TABLE>
those will foul out fast on his setup you shoudl just use a 7 if spark is blowing out switch to an 8
Re: (powerdbygarrett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerdbygarrett »</TD></TR><TR><TD CLASS="quote">im not trying to read through that entire thread if u can just give me a strait and simple answer that would be great thanks</TD></TR></TABLE>
stop being lazy
anyways, good old copper bkr7e is the plug you want. ngk stock number 6097. the bcp will work as well. might want to go to 8's after 500whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport »</TD></TR><TR><TD CLASS="quote">
just use a 7 if spark is blowing out switch to an 8</TD></TR></TABLE>
i dont think heat range will really affect spark blow out. reducing the gap will fix that. heat range has to do with keeping the tip at the correct temp to avoid fouling and pre-ignition.
stop being lazy
Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">SEARCH</TD></TR></TABLE>
seriously its not that hard.
https://honda-tech.com/zerothread?id=2033634
https://honda-tech.com/zerothread?id=1654537
https://honda-tech.com/zerothread?id=1613652
https://honda-tech.com/zerothread?id=1557719
https://honda-tech.com/zerothread?id=1111447
i could go on.
edit: straight from the FI FAQ. https://honda-tech.com/zerothread?id=877602
i could go on.
civicracingteam
02-17-2005 03:41 AM
hybrid_vtec
15
07-30-2004 01:37 PM
