slow spool on 50 trim y????
Old Jul 27, 2007 | 11:07 PM
EKlscoupe_98's Avatar
Default slow spool on 50 trim y????
so i have a bone stock b18a with 50k on stock rebuild. i have kooks ramhorn with a t3/to4e .60 a/r intake side .63 a/r hotside. 2 1/2 dp and exhaust no cat. i'm running 14 psi i'm not starting to spool till 4500 and not reaching full boost till 6000 - 6500. trying to figure out y the late spool anyone have any ideas thanks for any help
Old Jul 27, 2007 | 11:08 PM
Default Re: slow spool on 50 trim y???? (EKlscoupe_98)
bump for the first min that and i'm really drnk lol
Old Jul 28, 2007 | 07:01 AM
bump need some help here
Old Jul 28, 2007 | 07:19 AM
93turbo16's Avatar
Check all of your connections on the charge piping and also make sure there aren't any leaks pre-turbo.
There was definitely something causing that turbo to spool slow, just couldn't put my finger on it.
Old Jul 28, 2007 | 08:06 AM
boosted k20's Avatar
Default Re: slow spool on 50 trim y???? (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Check all of your connections on the charge piping and also make sure there aren't any leaks pre-turbo.
There was definitely something causing that turbo to spool slow, just couldn't put my finger on it.</TD></TR></TABLE>
def check for boost leaks. that will result in very slow spool time.
Old Jul 28, 2007 | 09:08 AM
CivicVX94's Avatar
internal or external wastegate? maybe it's leaking?
Old Jul 28, 2007 | 10:13 AM
CoreyR's Avatar
Default Re: slow spool on 50 trim y???? (CivicVX94)
sounds like pre turbo leaks. check to make sure the wastegate is hanging open and that your turbo&gt;manifold gasket isnt leaking. ive had similar problems.
Old Jul 29, 2007 | 06:45 PM
Default Re: slow spool on 50 trim y???? (CoreyR)
got some new couplers and clamps for the ic piping. also noticed that it looks like the wastegate was leaking on the backside going to oreder some new gaskets. hopefully that was my problem i keep this updated thanks for the help so far
Old Jul 29, 2007 | 07:00 PM
CoreyR's Avatar
you would be suprised how much a small exhaust leak will affect spool. if its leaking pre-wastegte thats very likely the problem
Old Jul 30, 2007 | 11:05 AM
new gaskets in no leaks now but still slow spool
Old Jul 30, 2007 | 03:23 PM
young noob's Avatar
does it spool any faster? how big is your exhaust, or small rather..........
Old Jul 30, 2007 | 03:25 PM
young noob's Avatar
Default Re: slow spool on 50 trim y???? (young noob)
didnt catch the 2.5 exhaust at first, only thought that was downpipe on maybe stock exhaust.....how much boost are you running on the spring on the wastegate? and how much shows on the boost gauge?
Old Jul 30, 2007 | 03:27 PM
da_dude's Avatar
Go over all your couplers and make sure it's clamp down tight. Check couples for any wear on them. It's a boost leak somewhere. Check your manifold too.
Old Jul 31, 2007 | 07:33 AM
Default Re: (turb20_vtec)
pulling the manifold checking for cracks going to put a new gasket on. but i keep checking and double checking starting to think its the turbo will post up later if new exhaust manifold gasket doesn't work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob &raquo;</TD></TR><TR><TD CLASS="quote">didnt catch the 2.5 exhaust at first, only thought that was downpipe on maybe stock exhaust.....how much boost are you running on the spring on the wastegate? and how much shows on the boost gauge?</TD></TR></TABLE>
running 14 psi on the spring and showing 14 inside on the gauge going to post dyno graph tonight
Old Jul 31, 2007 | 06:41 PM
Default Re: (EKlscoupe_98)
bump
Old Jul 31, 2007 | 07:53 PM
batboyvaj's Avatar
make one of these
http://www.vfaq.com/mods/ICtester.html
Old Jul 31, 2007 | 09:30 PM
Default Re: (batboyvaj)
anyone else try this ? going to see if i can find some leaks
Old Jul 31, 2007 | 10:26 PM
ironcheftony's Avatar
prolly bkuz u have a big turbo and ur tryin to get alot of psi out of it on a stock motor in a low gear, thats prolly not going to work out too well maybe.........?
Old Aug 2, 2007 | 01:30 PM
Default Re: (ironcheftony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj &raquo;</TD></TR><TR><TD CLASS="quote">make one of these
http://www.vfaq.com/mods/ICtester.html</TD></TR></TABLE>
okay made one of these the flang for the bov is leaking pretty good around it. couldn't even build 1 psi with it leaking using a bike pump.
Old Aug 2, 2007 | 03:49 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKlscoupe_98 &raquo;</TD></TR><TR><TD CLASS="quote">
okay made one of these the flang for the bov is leaking pretty good around it. couldn't even build 1 psi with it leaking using a bike pump.</TD></TR></TABLE>
Found your problem.
Old Aug 5, 2007 | 08:32 AM
Default Re: (93turbo16)
lets see i'm still spooling late i've haven't been driving due too i want to get all the leaks taken care of. so far the the places i found leaks are the weld around bov, the bov itself, my iat sensor, a hole in one of the couplers.
Old Aug 5, 2007 | 08:53 AM
lakai_19's Avatar
your intercoolermight have aleak in it
Old Aug 5, 2007 | 02:50 PM
batboyvaj's Avatar
you need something to pump air a little quicker to find you leak. try to get a air compressor to pump air in faster to help find your leak
Old Aug 5, 2007 | 06:57 PM
going to get a portable air tank tomorrow sometime. i'm going to find them all idc what it takes.
Old Aug 5, 2007 | 07:13 PM
ITS_Dunn's Avatar
With all those leaks you're almost just as well off to start it all over again
Keep on them and that is your problem for sure. You should see full boost on that thing by 5500 or less by the end of it.
