Noob Question Boost Adjustmen
Old Jul 26, 2007 | 11:02 PM
Horseofcourse's Avatar
Default Noob Question Boost Adjustmen
how do i lower my boost without a Boost controller? cause i want to fire my motor and make sure everything is on right and working correctly. ect... is there anyway to control or limit it before i get a EBC or MBC? and p.s. where should i tap my autometer boost gauge at?
Old Jul 26, 2007 | 11:10 PM
Kyle R's Avatar
Default Re: Noob Question Boost Adjustmen (Horseofcourse)
Just don't go into boost until you make sure everything is ok. What will you be using to tune the car? The wastegate will control boost. What spring are you using? Tap the boost gauge into a vacuum line connected to the intake manifold.
Old Jul 26, 2007 | 11:14 PM
numbnuts22715's Avatar
You cant really lower the boost pressure at all. If its an internal wastegate, you can increase the pressure(I believe) by shortening the arm to the actuator, but i dont think theres a way to lengthen it to lessen boost pressure.
To stay out of boost, just dont accelerate very fast, and itll be fine.
JACER63's Avatar
Default Re: Noob Question Boost Adjustmen (herecomesboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herecomesboost &raquo;</TD></TR><TR><TD CLASS="quote">Just don't go into boost until you make sure everything is ok. What will you be using to tune the car? The wastegate will control boost. What spring are you using? Tap the boost gauge into a vacuum line connected to the intake manifold. </TD></TR></TABLE>
what he said is about it.....
Old Jul 26, 2007 | 11:51 PM
Default Re: Noob Question Boost Adjustmen (JACER63)
external wastegate fellas....thanks for the input though and for my gauge ya ill tap it thanks on that
Old Jul 26, 2007 | 11:56 PM
Kyle R's Avatar
What PSI spring do you have in the wastegate?
Old Jul 27, 2007 | 01:42 AM
7psi
Old Jul 27, 2007 | 01:55 AM
Kyle R's Avatar
Well that will be your lowest possible setting (unless you get different spring). With a boost controller, you will only be able to go up starting at 7psi.
Old Jul 27, 2007 | 10:39 AM
what will be easier? manual boost controller or EBT
thegatekeeper14
Jul 6, 2010 12:53 PM
builtboostedteg
Apr 5, 2006 05:19 PM
MachAF
Jun 27, 2003 05:14 PM
Quetzolcotl
May 24, 2002 01:30 AM
SIK IN DA HED
Sep 13, 2001 03:16 AM
