does this make sense?
Old Jul 29, 2007 | 05:01 PM
RTW DC2R's Avatar
Default does this make sense?
went to the track today for some test runs. I recently swapped in a smaller spring into my wastegate because I plan to install a new boost controller. after my first test run, I noticed my MPH was way down and my ET wasnt that great. it was really hot out today so I thought maybe that was part of it or there was some heat soak going on. on the next run I notice my boost wasnt reaching what it used to when I had the larger spring installed, even with the boost controller on. it was still a good 5psi off. I had to turn the boost controller way up about 15% for it to hold boost with the smaller spring where it normally does when I had the larger spring installed. is this normal when installing a smaller spring? you have to actually turn up the boost on your boost controller in order for the spring to hold?
Old Jul 29, 2007 | 05:08 PM
90dxhmt's Avatar
Default Re: does this make sense? (RTW DC2R)
What PSI were the springs ?
Old Jul 29, 2007 | 05:10 PM
RTW DC2R's Avatar
the original was 9psi, the new one is 5.8psi
Old Jul 29, 2007 | 05:13 PM
dpetro1's Avatar
by smaller spring i assume you mean lighter/lower psi. so yes you will have to increase the boost contoller duty cycle to reach higher boost. 15% on different springs will create different boost levels.
Old Jul 29, 2007 | 05:16 PM
RTW DC2R's Avatar
Default Re: does this make sense? (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">by smaller spring i assume you mean lighter/lower psi. so yes you will have to increase the boost contoller duty cycle to reach higher boost. 15% on different springs will create different boost levels.
thanks. can you explain duty cycle for the boost controller? I know the concept with injectors, so I assume its similar with a boost solenoid.
Old Jul 29, 2007 | 05:25 PM
dpetro1's Avatar
in all honest im not sure. i mean i know the solenoid controls the airflow but how exactly duty cycle or whatever you wanna call it works, id like to know too.
Old Jul 29, 2007 | 05:26 PM
boostedcivicsir's Avatar
Mr. Badwrench
duty cycle on anything is % of on time vs off time. yes your settings will be different with a different base. so in your boost controller, it is a solenoid actuated air valve, it is pulsed fast like your injectors. the faster it pulses, the more boost it dumps or presses down on the top. 80% means it is open 80% vs 20% of given time.
i am pretty sure that it is with any ammount of time. i know on my old welder it had 15% duty meaning it can run full bore for 1.5 minutes out of 10 before it needs to cool down, it was a little buzz box with no fan.
91integraLSVTEC
Oct 21, 2009 11:09 AM
1990hondaHF
Jan 16, 2008 11:57 AM
*Boostwerks*
Apr 3, 2005 05:55 PM
hybrid901
May 2, 2003 02:49 PM
