NO BOOST! i mean ZERO
Old Jul 30, 2007 | 07:31 PM
supabang's Avatar
Default NO BOOST! i mean ZERO
i changed my timing belt and now i build zero boost... any ideas?
Old Jul 30, 2007 | 07:32 PM
Schister66's Avatar
Man U FTW
make sure all your couplers are good and there aren't any major vac leaks....also your timing could be really off, but idk if it would NEVER build boost....
Old Jul 30, 2007 | 07:43 PM
agrn93ls's Avatar
Default Re: (Schister66)
unrealted to belt itself.
just check anything you "undid"
does it run normally after the belt change, to establish timing is correct. should build boost either way.
Old Jul 30, 2007 | 07:49 PM
Topdawgg's Avatar
like was said, not a timing belt issue... check the things you took apart to get at the belt...
Old Jul 30, 2007 | 09:13 PM
supabang's Avatar
i didn't touch anything "turbo" related when doing the timing belt. I'm certain that i didn't. It's just the belts you mess with. I have no idea. According to the timing gun my timing is on. but as you mentioned, i should still build boost either way. I'm guessing that maybe bent valves is the culprit? could that be a reason i don't built boost?
Old Jul 31, 2007 | 03:04 AM
Topdawgg's Avatar
no, not at all... you would notice your engine wasnt running right at all, it would have nothing to do with no boost
Old Jul 31, 2007 | 06:03 AM
94c1v1cex's Avatar
Default Re: (supabang)
Just look over all your vac lines and make sure they're all connected. You could've knocked one off while working.
Old Jul 31, 2007 | 04:05 PM
lovey408's Avatar
Default Re: (94c1v1cex)
i had this same issue last week or so and people here helped me out.. follow alll ur intercooler pipings and double check if they are connected by touching them and observing closly.. i panickeddd as well cuz i didnt see anything unattached but wen i double checked i found a big leak on the coupler... just double check all the ic piping.
Old Jul 31, 2007 | 05:52 PM
Kyle R's Avatar
Default Re: (lovey408)
You don't hear any leaks? Can you hear the turbo spooling at all?
a1320honda
Apr 6, 2012 05:15 AM
dan's integra
May 25, 2006 12:35 PM
TurboHondaGuy
Nov 9, 2004 05:33 PM
Mr_Bojangles
Sep 29, 2004 09:29 AM
