B18c1 turbo a/r 0.63 or a/r 0.82 hotside
Hi, I have a crx with a b18c1 turbo. It's a fully built motor and wanted to achieve
425 whp. I have a sc61 turbo with 2 different housing. Which one is better with better spool without affecting the 425 whp? I am asking because I have a friend with the same kind of car and setup, but he is using the a/r 0.82. He is using the long geared ratio cable tranny y21 and it seems when he throws the 3rd gear, the rpm goes a little bit below 6000 rpm and it takes a while to get back to 8500 rpm.
He has about 380 whp and 15 psi. Any suggestions??
Re: B18c1 turbo a/r 0.63 or a/r 0.82 hotside (turboedc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboedc2 »</TD></TR><TR><TD CLASS="quote">.82</TD></TR></TABLE>
Re: (christion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by christion »</TD></TR><TR><TD CLASS="quote">That means that I'll have less MPH with the 0.63??</TD></TR></TABLE>
well if 425whp is all your looking for and the turbo that spools the fastest your choice would be the .63
Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegdude227 »</TD></TR><TR><TD CLASS="quote">is the 82 only good for high revving of a vtec motor or would it suit the ls motor to ?</TD></TR></TABLE>
Yes, unless you like a very narrow powerband
i would go with the .63 i had one on my GSR making 500 to 9.5 and i had a very very nice powerband with no boost dropping off. this was on a GT3040R
