oil sending unit oil feed line issue
Old 07-25-2007, 06:03 PM
jdmrex91's Avatar
Default oil sending unit oil feed line issue
Alright I mounted both of these with t adapter fittings to the back of my block where the oil sens was. Issue I am having is that the motor vibrates enough to make them leak. I could just tighten stuff up and it pry wouldnt leak but i would like to mount these on either the firewall or strut tower. What I am curious about is what have my boosted breathern here have done and how they have done it.
thankx in advance for all input
Old 07-25-2007, 06:25 PM
Kyle R's Avatar
Default Re: oil sending unit oil feed line issue (jdmrex91)
You should relocate the T to the firewall. All of the weight/vibrations can easily strip the threads otherwise.
Old 07-25-2007, 07:17 PM
Tippyman's Avatar
Default Re: oil sending unit oil feed line issue (herecomesboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herecomesboost &raquo;</TD></TR><TR><TD CLASS="quote">You should relocate the T to the firewall. All of the weight/vibrations can easily strip the threads otherwise. </TD></TR></TABLE>
Or just snap the **** off.
Old 07-25-2007, 07:30 PM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: oil sending unit oil feed line issue (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
Or just snap the **** off.</TD></TR></TABLE>
more like that.
Old 07-25-2007, 07:33 PM
Crx Jimmy's Avatar
get a small braided ss hose to go from the block to the T
Old 07-25-2007, 07:54 PM
TunerToys's Avatar
As long as you haven't used any 1/8NPT fittings in your block, you can clean up the installation by using one of our Oil Take Off fittings. We'll even send you a free one, if you'll PM us your address (from your jdmrex91 account).
They have the correct threads for the block and stock sensor, and two side ports with 1/8NPT threads for connecting your feed line and one other accessory (like a feed line to an oil tee on the firewall). You cannot mount an aftermarket sending unit to our adapter, only the stock sending unit, and feed lines. Use a remote line to mount any aftermarket sending units.
Here is a pic...
You can check out the installation of one of these here - Turbo Install Blog It's a log post, so just search the page for "Tuner Toys block fitting", and you''l be in the right spot. You can click on the pics to enlarge them.
Hope that helps,
Craig
Old 07-25-2007, 10:48 PM
Kyle R's Avatar
Default Re: oil sending unit oil feed line issue (TunerToys)
Hahah. Or that
Old 07-25-2007, 10:56 PM
jdmrex91's Avatar
great feedback guys
Craig I have already used the aforementioned fitting on my block does that mean I can no longer use the fiting that you listed above?
Old 07-25-2007, 11:00 PM
jdmrex91's Avatar
also where can I get the small braided line like my oil feed line but only like a foot or foot and a half of it instead of 3 feet of it? Can anyone tell me that?
as before thankyou for all the input it is well used and appreciated.
Old 07-26-2007, 03:24 AM
BDogggUT34's Avatar
http://www.mcmaster.com , i got my entire oil setup from there for $40
Old 07-26-2007, 04:31 AM
turboteg2nv's Avatar
I'm selling an oil line/firewall mounting kit (Stan's) if you're interested..
https://honda-tech.com/zerothread?id=2035881
Old 07-26-2007, 10:32 AM
jdmrex91's Avatar
Default Re: oil sending unit oil feed line issue (turboteg2nv)
pm'd
thankx for all the info
Old 07-26-2007, 11:40 AM
stealthmode62's Avatar
Over 1000 oil line kits sold with Craigs fitting, and I'd never change it. For the aftermarket oil pressure sensor, you will need an 18" feedline up the firewall to a T.
Old 07-26-2007, 04:52 PM
TunerToys's Avatar
Default Re: oil sending unit oil feed line issue (stealthmode62)
Thanks Stevemode!
We've sold an equal number of Stealthmode Oil Line Kits, and not one customer complaint!
Thanks Stevemode!
Old 07-26-2007, 07:54 PM
jdmrex91's Avatar
thankx for the offer, wish you would have let me know sooner I already have a line on the relo kit
for effort and all the help!
Evilparadize
03-08-2008 08:19 PM
g2turbo
11-01-2006 03:52 AM
hondaeg8
05-22-2006 03:12 PM
TA Performance
02-06-2005 12:27 PM
SpoolinEK
Welding / Fabrication
08-29-2004 10:21 AM
Quick Reply: oil sending unit oil feed line issue
