piston and rod install
Old Jul 31, 2007 | 08:12 AM
patrick4588's Avatar
Default piston and rod install
im toying with the idea of getting some forged pistons and rods for my gsr. how much would a shop charge to install them and bore out the block to 81.5mm? just a ballpark would be nice.
Old Jul 31, 2007 | 08:14 AM
Schister66's Avatar
Man U FTW
just the assembly fee??
I think when i was quoted a year ago, most were in the $400-500 range for assembly only....
Old Jul 31, 2007 | 08:17 AM
like if i bought the pistons and rods, how much would it cost to get them put in and bore the block out .5mm
Old Jul 31, 2007 | 08:58 AM
MeanGreenMachine's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">just the assembly fee??
I think when i was quoted a year ago, most were in the $400-500 range for assembly only....</TD></TR></TABLE>
+1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick4588 &raquo;</TD></TR><TR><TD CLASS="quote">like if i bought the pistons and rods, how much would it cost to get them put in and bore the block out .5mm</TD></TR></TABLE>
the machining may be an extra fee since the shop who is building your motor may have to send it out to a local machine shop unless they have the tools, knowledge and equipment to bore the block out themselves
Old Jul 31, 2007 | 09:02 AM
should i be fine doing stock bore then?
Old Jul 31, 2007 | 09:05 AM
morgan@synapse motorsport's Avatar
Default Re: (patrick4588)
i would expect to pay between 700 and 800 for the assembly and machining
Old Jul 31, 2007 | 09:07 AM
young noob's Avatar
if you are on boost stock bore is just fine, only big hp goals are really needed to extend the bore, and those are usually done by more experienced people, no offense....... but my machinist charges 150 bucks for bore and hot tank
Old Jul 31, 2007 | 09:48 AM
ok so if i stuck with stock bore then i should expect about 400-500 for piston and rod install. what bearings do i need to buy, or just re use the stock ones?
Old Jul 31, 2007 | 10:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick4588 &raquo;</TD></TR><TR><TD CLASS="quote">ok so if i stuck with stock bore then i should expect about 400-500 for piston and rod install. what bearings do i need to buy, or just re use the stock ones?</TD></TR></TABLE>
dont reuse the bearings, u can get a set of acl's or a set of oem honda bearings.
i would suggest 81.5mm bore. it will let you start fresh.
Old Jul 31, 2007 | 10:12 AM
Schister66's Avatar
Man U FTW
i'll second the 81.5mm bore option....its best to start fresh. I would also go w/ standard Honda bearings, but take the engine to a shop, have them machine all the parts and then order bearings....it would suck if you bought parts and needed oversized bearings due to machining
Old Jul 31, 2007 | 10:17 AM
young noob's Avatar
yea, standard honda bearings are greens, but you have to get the oil clearance measured with a mic.....you don't want to throw a bearing within the first seconds of start-up.....that would suck
Old Jul 31, 2007 | 10:19 AM
Schister66's Avatar
Man U FTW
Default Re: (young noob)
let the shop order the bearings or have them measure your clearances and give you the specs so you can order them....i wouldn't do anything until they get you the numbers because like Young Noob said, you could spin a bearing easily or lose oil pressure due to a larger gap in the bearings
Old Jul 31, 2007 | 10:42 AM
young noob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">let the shop order the bearings or have them measure your clearances and give you the specs so you can order them....i wouldn't do anything until they get you the numbers because like Young Noob said, you could spin a bearing easily or lose oil pressure due to a larger gap in the bearings</TD></TR></TABLE>
paulITR
Nov 9, 2007 10:47 AM
Leo.
Nov 8, 2006 08:17 AM
CivicVX94
Feb 6, 2006 11:35 PM
Sport_Injected
Oct 6, 2004 05:16 PM
p1ccoloz
Feb 7, 2004 08:46 PM
