Boosted D16A1
Old Jul 29, 2007 | 08:24 PM
InvaderTrax's Avatar
Default Boosted D16A1
D16A1 from (and going back into) 89 Integra
75.5mm bore
86/87 rods
88/89 Nippon P29 pistons
Line bore crank journals
Balance crank, rods, etc
P&P head and intake manifold
272 intake, 260 exhaust cams from Delta
CT26 turbo at 6 PSI
Tuned by myself with Turboedit
What do you think? Pulling the motor tomorrow to get started. I need to know what injectors to use, and pick up an HF manifold. Also, what oil weight would you recommend?
Old Jul 29, 2007 | 08:49 PM
wakedoe's Avatar
Default Re: Boosted D16A1 (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">D16A1 from (and going back into) 89 Integra
75.5mm bore
86/87 rods
CT26 turbo at 6 PSI
What do you think? Pulling the motor tomorrow to get started. I need to know what injectors to use, and pick up an HF manifold. Also, what oil weight would you recommend?</TD></TR></TABLE>
If you're using a CT26, which is prob. beat up to hell and back then DSM 450s is your equally ghetto answer. Also you'd need a toyota adaptor plate for the HF, that is if it fit on the d16a1, which iirc it wont.
Old Jul 29, 2007 | 09:24 PM
It'll bolt to an A1, and I just have to gasket match it to make it completely line up. I was going to make my own adapter plate for the turbo. I wasn't sure if 450 would be too much or not
Old Jul 30, 2007 | 06:19 AM
Joseph Davis's Avatar
75.5mm bore
86/87 rods
CT26 turbo at 6 PSI
Intentionally selecting 86-87 rods is useless. They "look" beefier... they also "look" cruder and of lower quality. No one has ever made any better reliable power off of them than with 88+ rods. Run 'em if it's what is in your engine, don't waste your time seeking them out.
Why line bore the crank journals? Better off finding a block that hasn't been abused.
Why balance the crank and the rods? They are generally excellent pieces that don't need balancing.
Why port and polish your head? They are generally excellent from the factory, and with a 6 psi target... heh. You could turn up the boost to 7 psi, make more power than off porting and polishing, accrue zero loss in reliability, and save yourself a whole lot of time and effort.
Cams may/may not be a decent idea, D16A1 isn't as strangles by the factory cam as it's big brother the LS is. Deltas are inexpensive and work well for what they are, though. It's up to you.
Frankly, I'd do without every last bit of crap I criticised (including the cams) and save a few bucks on Eagles and Vitaras. Your CR will be a hair on the low side with the bigger A1 combustion chamber, but that won't affect your spool time and it will make your setup much more resilient and detonation-proof. Get a bigger MAP sensor and turn the boost up and enjoy the car - if built/tuned right it won't be any less reliable than the build you have planned.
hatchinprogress
Dec 23, 2005 11:13 AM
BryanEk
Feb 27, 2005 04:14 PM
done
Nov 4, 2002 08:25 PM
