Building The B16 Need Some Imput!!!
Old Jul 23, 2007 | 08:09 PM
red_hatchback's Avatar
Default Building The B16 Need Some Imput!!!
Well decided to build the B16 shortblock so it can handle boost a bit better...This is what I was planing:
B16 Shortblock
Mahle Pistons stock bore 9.2:1 compression
Scat Rods
B16 Head
GSR cams
ARP headbolts
Ferrea springs and retainers
Blox Intake Manifold
70mm Throttle Body
Transmission
B16 Hydraulic tranny
Exedy Stage 2 Clutch
Fuel
Walbro 255lph
Blox FPR
Precision 780cc Injectors
Turbo Stuff
Ramhorn manifold
3" exhaust
Precision sc3431e 57trim 540hp capable
Tial 38mm Wastegate 15lb spring
FMIC and greddy bov
Management
Neptune
AEM Wideband
Ok the question is can this setup handle 450hp??? Or what do i need to upgrade
Modified by red_hatchback at 9:26 PM 7/23/2007
Old Jul 23, 2007 | 08:41 PM
blinx9900's Avatar
Default Re: Building The B16 Need Some Imput!!! (red_hatchback)
sounds good, i heard mahle pistons arent really forged thouhg, there some high tech aluminum cast. but why are you getting valve springs and retainers for stock cams? also im assuming you meant arp headSTUDS? one last thing the exedy stage II is rated at 228wtq, youll be making more than that from what it sounds like so on paper, it wont hold, though im not sure about the real world experience on that clutch, anyone care to chime in on the clutch?
Old Jul 23, 2007 | 10:20 PM
RCautoworks's Avatar
Just curious but why not run a different cam, specially if your upgrading your intake components ?
Old Jul 23, 2007 | 10:36 PM
Boner_Ben's Avatar
Default Re: Building The B16 Need Some Imput!!! (RCautoworks)
Motor setup should easily hold that power. Good valvetrain is important because with a b16 you will have to rev it to stay in the powerband. I made 570whp with my stock sleeve'd b16 JE/Eagle combo and it held together for a while before eventually cracking a sleeve. Probably made close to 100 passes at the 425-450whp level with it on pump gas.
Old Jul 23, 2007 | 11:47 PM
quicksilver1689's Avatar
i ♥ snails
damn that speaks to the quality of your motors assembly
Old Jul 24, 2007 | 05:45 AM
Default Re: (quicksilver1689)
well the reason i'm using gsr cams is that i don't really know which ones to get if someone can help with that, and also what clutch would you recommend??
Old Jul 24, 2007 | 05:54 AM
numbnuts22715's Avatar
type r cams increase the power considerably.
I dont know much about aftermarket cams though, just have heard good things about type r's
the type r cams in refering to are 00, 01 itr, or ctr cams.
Old Jul 24, 2007 | 07:58 AM
Default Re: (numbnuts22715)
I would say Type R cams
Old Jul 24, 2007 | 10:53 AM
White Smoke's Avatar
i my honda
Global Mod
R cams are overkill unless you already have them IMO. I would stick with the GSR cams.
Old Jul 24, 2007 | 11:06 AM
PiMpIn's Avatar
Default Re: Building The B16 Need Some Imput!!! (White Smoke)
the gsr cams should be fine
Old Jul 24, 2007 | 11:10 AM
agrn93ls's Avatar
Default Re: Building The B16 Need Some Imput!!! (PiMpIn)
you may be able to make enough power to max those injectors with that setup. think about maybe 1000's?
Old Jul 26, 2007 | 12:57 PM
Default Re: Building The B16 Need Some Imput!!! (agrn93ls)
Can someone help me out on what clutch to get right now i'm looking at the competition stage 5 clutch 6 puck with springs...what do you guys think???
Old Jul 26, 2007 | 02:06 PM
PiMpIn's Avatar
nah go 6puck unsprung that is the ******* many people dont like it but trust me it will get the job don very well my buddy has over 25000 miles on his and still does not slip.
Old Jul 26, 2007 | 03:27 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_hatchback &raquo;</TD></TR><TR><TD CLASS="quote">Can someone help me out on what clutch to get right now i'm looking at the competition stage 5 clutch 6 puck with springs...what do you guys think???</TD></TR></TABLE>
if you plan on drag racing then go for unsprung, if you drive a lot on the street a sprung hub is better imo.
Old Jul 26, 2007 | 04:30 PM
PiMpIn's Avatar
Default Re: Building The B16 Need Some Imput!!! (blinx9900)
the 6puck unsprung is not that crazy its actually very mild and yet still nasty, it would be very well on the street.
Old Jul 26, 2007 | 05:57 PM
Garage 808 Hatch's Avatar
i ran those exact pistons, made 463whp on my b16.
blitzman
Aug 4, 2015 06:41 AM
lambertincorp
Mid-Atlantic (Sales)
Jul 21, 2007 08:56 AM
sprayin95hatch
Jul 12, 2005 08:00 PM
C8V6C
Aug 8, 2004 11:13 PM
C8V6C
Jul 19, 2004 12:09 AM
