H22 turbo setup
Subscribe
Jul 25, 2007 | 07:51 PM
I looked around and I wanted to ask you guys what would be a good size turbo for a h22a turbo setup?
Reply 0
Jul 25, 2007 | 09:22 PM
Re: H22 turbo setup (94h22aAccord)
a big one!
you have to list your goals and a budget before anyone can really help you out.
Reply 0
Jul 26, 2007 | 12:42 AM
I have a t4/t67 on mine.
Reply 0
Jul 26, 2007 | 06:18 AM
It depends on your power goals.
Reply 0
Jul 26, 2007 | 09:45 AM
I would like to shoot for the 300 to 450whp and as for the budget I would like to do it in stages due to the fact of me having a family. Have any of you guys done setups in stages? or should I just wait and have everything done all at once? what would be the easy way to get this accomplished?
Reply 0
Jul 26, 2007 | 09:46 AM
If you want to do it in stages... have your motor built first. Drive on the built motor for a while then throw the turbo kit on.
That's your best bet.
Reply 0
Jul 26, 2007 | 11:10 AM
Are there any risks involved in driving around with a turbo built motor with no turbo on it?
Reply 0
Jul 26, 2007 | 11:22 AM
Re: (InvaderJim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderJim &raquo;</TD></TR><TR><TD CLASS="quote">Are there any risks involved in driving around with a turbo built motor with no turbo on it?</TD></TR></TABLE>
No.
The safest way to go is to at least have your new EMS and injectors installed and have the car tuned for NA until it is turbo. Some guys will throw in a built motor and keep all their fueling and electronics stock but going with a lower compression piston and changing things up in the head will alter your a/f's a bit. For the most part, if your build is simple such as pistons/rods/sleeves you'll be fine but I wouldn't recommend introducing heavy loads to the new motor on a stock ecu/fuel system.
Reply 0
Jul 26, 2007 | 12:16 PM
I'm running a t3/t04e on mine and love it. My motor is still all stock and I'm running 9 lbs of boost. This turbo suits my needs because A) I wanted something that would spool quickly and B) I'm not concerned with running tons of boost and making tons of hp. I just wanted something fun on the street and would be relatively dependable.
Reply 0
Jul 26, 2007 | 12:35 PM
Ok got it. So running a built motor without a turbo is fine as long as you swap the injectors and ecu as well. I have some questions I'm going to PM you.
Reply 0
Jul 26, 2007 | 01:01 PM
Turbonetics T88
Reply 0
Jul 27, 2007 | 08:04 AM
Re: H22 turbo setup (PrecisionH23a)
thanks that's helps me a lot.
Reply 0
Aug 7, 2007 | 03:08 PM
Re: H22 turbo setup (FastechAccord)
with what manifold
Reply 0
Aug 7, 2007 | 03:14 PM
Re: H22 turbo setup (2point2)
a big one!
Reply 0
Subscribe
