Thermo Valve ???
Old Jul 25, 2007 | 01:19 PM
jarven093's Avatar
Default Thermo Valve ???
ok so i took my charge pipes off the throttle body and was told that if the lower left hole inside the throttle body is pulling vacc. that the thermo valve is unscrewed and thats exactly what mine is doing how do i fix this ( how to tighten thermo valve?? thanks
Old Jul 25, 2007 | 02:15 PM
notfastenough's Avatar
Default Re: Thermo Valve ??? (jarven093)
search fitv or put your topic title in the search engine, be sure to check "archived"
Old Jul 25, 2007 | 06:48 PM
SuperTeg95's Avatar
Default Re: Thermo Valve ??? (notfastenough)
Your FITV is on the bottom of your throttle body. You can take it off and there is 2 bolts that hold a plate on. Take that plate off and inside is a big plastic plug. You can screw it in and then put it back together. Your idle should get better if that was your problem.
jofu
Honda CR-V & Element
Apr 20, 2018 06:18 AM
Excelerate
May 17, 2003 04:56 AM
HondaCutter
Dec 4, 2002 03:05 AM
