just fired up my b18b turbo Oil and Break leaks help!
1. where my oil return line meets the pan.... everythings tight... and i got teflon tape up on it. Can i use high heat silicone?
2. Sounds like a vaccum leak comming from the brake booster area any ideas? what can i use to seal it?
3. Brake lines leaking what can i use to seal it that wont be ate by the brake fluid? Teflon on all fittings btw.
Re: just fired up my b18b turbo Oil and Break leaks help! (Horseofcourse)
Are you using AN fittings for the return line? I had this problem as well and what i thought was "tight" was just not tight enough. I cranked on it a little more and finally stopped leaking. You could try the high temp silicone, i have some around some bolts on the oil pan that seemed to leak a tiny bit and that worked. Since you're using teflon in all places and still getting leaks, it just sounds like things aren't tight enough even though you say they are.
Re: just fired up my b18b turbo Oil and Break leaks help! (BDogggUT34)
No they are tight.... way tight. High temp silicone sounds like my guy.. anything i can use for the brake lines?
