car want build boost...
my car will not build boost, it will build 1 psi and hold it and it is a new turbo. what do yall think the problem could be? "please help"
Re: car want build boost... (1sic3dr)
disconnect the waste gate and see what it does!... no jk
as mentioned check couplers etc... does it feel like its boosting.. as in pulls good? maybe boost gauge not reading properly?
i would vote leak though
Re: (elementb16a)
i was there when we tried to get it to boost and yea we even blocked off the wastegate flange lol and it still only built 1 pound and we checked the charge pipes and couplings and such and no it definatly doesnt pull like its building boost
Re: (B18C-YA!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C-YA! »</TD></TR><TR><TD CLASS="quote">we tried it with no wastegate we put a block off on the flange and still nothing</TD></TR></TABLE>
Did you disconnect the boost controller first? I think that's what hes getting at.
Disconnect the boost controller and run off the wastegate.
Re: (96vtecI4)
Build a boost leak tester and hook it up to a compressor and see if the intake system is holding any pressure, easiest and cheapest test you can do.
Most of the stuff you can find at a home depot, probably 8 bucks tops. If you don't have a compressor, a little brother, some sugar and a bike pump will be fine.
i highly doubt it has anythign to do with the turbo itself. check for exhaust leaksto. if exhaust is exscaping before it meets the turbo, its obviously not going to spool properly.
Re: (raiden571)
its gonna be pretty noticable if theres a leak before the turbo..its gonna be loud, either your charge pipes are leaking, or the boost controller is jammed/broken, also check the bov could be leaking from there too
Re: (96vtecI4)
yea weve checked everything and how could it be the wastegate if we took the wastegate off and put a block off plate on it? but yea i think it more than likely has something to do with the boost controller also
Re: (B18C-YA!)
well we unhooked the boost controller and nothing happend still only built 1 lb plus theres a little bit of oil in the inlet of the turbo? im takin it thats not a good sign
