Boost Gauge not reading accurately!!!
Old Jul 31, 2007 | 07:01 AM
hondamonkey's Avatar
Default Boost Gauge not reading accurately!!!
My Setup:
Stock b16a2
t3/t4 turbo .48/a/r .63
tial 38mm wastegate (0.6 bar)
Precision 350hp FMIC
P-Fab Turbo Manifold
2.5' Downpipe--> 2.25 HKS catback exhaust
Hallman Boost Controller (set to the minimum level possible)
RC 550 Injectors
Vortech BOV
Walbro 255 Fuel Pump
P06 W/ Crome basemap
My boost gauge will not read over 3psi even though my wastegate is a 0.6 bar (8.70psi). I have the gauge vacuum line running to the intake manifold...Any ideas of what could be wrong??? Even when I turn the boost controller up it doesn't go over 3psi but the car feels faster... HELP ME PLEASE!!!
Shot with DSC-P100 at 2007-07-31
Old Jul 31, 2007 | 07:08 AM
agrn93ls's Avatar
Default Re: Boost Gauge not reading accurately!!! (hondamonkey)
um get a new gauge maybe?
not that hard to figure out.
if you know its makin more boost but dosent register on gauge the only things it could be are a improper connection, leak to gauge or kink/restriction in line to gauge.
Old Jul 31, 2007 | 07:16 AM
Default Re: Boost Gauge not reading accurately!!! (agrn93ls)
the gauge works fine....literally was in my cousins boosted car a week ago reading 7psi. I'll check for any messed up connections at the back of the gauge itself.
Modified by hondamonkey at 8:36 AM 7/31/2007
Old Jul 31, 2007 | 07:58 AM
da_dude's Avatar
If it was working before then there must some leak somewhere or the line you are using must have something stuck in the line. Or just get a different boost gauge. What kind of boost gauge is it?
Old Jul 31, 2007 | 08:04 AM
Default Re: (turb20_vtec)
Its an autometer gauge....the vacuum reads fine....about 21 at idle
Old Jul 31, 2007 | 08:16 AM
patrick4588's Avatar
perhaps you have a humonguos boost leak and are only making 3psi. and you only feel faster because your mind is playing tricks on you. go to a dyno...
Old Jul 31, 2007 | 10:07 AM
Default Re: (patrick4588)
perhaps...any other ideas?
Old Jul 31, 2007 | 10:10 AM
spets's Avatar
Default Re: (hondamonkey)
seriously.. check your connections and your lines. you don't need "any other ideas". that's all there is to it.
Old Jul 31, 2007 | 10:11 AM
jmm96gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamonkey &raquo;</TD></TR><TR><TD CLASS="quote">perhaps...any other ideas?</TD></TR></TABLE>no new ideas. I would say check connections to the boost gauge as stated earlier and check for boost leaks
Old Jul 31, 2007 | 10:12 AM
EG civic's Avatar
Boost leak somewhere, check everywhere first. Or make sure theres no kinks or anything in the like running to the guage.
Old Jul 31, 2007 | 10:14 AM
Schister66's Avatar
Man U FTW
you basically have 4 options as i see it
1. Boost gauge is broken...its an Autometer so it can break
2. You have a boost leak somewhere in the system
3. The line leading to the boost gauge is kinked or the gauge is stuck
4. Somehow your car isn't building anymore boost...possibly a fire ring or boost controller problem
Old Jul 31, 2007 | 10:25 AM
jameelrose's Avatar
what does the datalogging in crome say?
Old Jul 31, 2007 | 10:33 AM
Default Re: (Schister66)
1. If it was broken, would the vacuum still read??
2. Gonna re-check everything when I get home.
3. The line to the boost gauge will also be checked once I get home.
4. What is a fire ring?? Please explain....doesn't sound good!
Also, can a boost controller take the boost below the wastegate bar (.6)? In other words, can the boost controller take me lower than the 8.70 psi??
Old Jul 31, 2007 | 10:39 AM
quicksilver1689's Avatar
i ♥ snails
fire ring is in the waste gate
Old Jul 31, 2007 | 10:40 AM
Default Re: (jameelrose)
will be doing the datalogging on friday...
Old Jul 31, 2007 | 11:16 AM
Schister66's Avatar
Man U FTW
good luck...let us know if you figure it out
Old Jul 31, 2007 | 11:23 AM
SOHCD16y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamonkey &raquo;</TD></TR><TR><TD CLASS="quote">will be doing the datalogging on friday...</TD></TR></TABLE>
If you want a quicker way to check it put on a boost cut at like 4psi and see if the car hits it.
Old Jul 31, 2007 | 11:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">good luck...let us know if you figure it out</TD></TR></TABLE>
Will do!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">
If you want a quicker way to check it put on a boost cut at like 4psi and see if the car hits it.</TD></TR></TABLE>
How do I do that??
Old Jul 31, 2007 | 11:42 AM
Unsivil_audio's Avatar
I'd borrow someone else's known working boost gauge and try that. Prolly bad gauge imo. And yes I read it came off a working car a week ago.
Old Aug 6, 2007 | 06:47 PM
Default Re: (Unsivil_audio)
Thanks guys a million....not sure why the gauge wasn't reading over 4psi....but I got tuned and made 216whp with 154tq @ 7psi.....I was happy because the timing was low and the tune was very very conservative. I also have 2 major boost leaks at the manifold (seems warped) and another one at the downpipe flange. The tune was rushed and it was dynoed at 98 degrees.
Old Aug 6, 2007 | 06:51 PM
boost cut is set @ 10psi alsoo
Old Aug 6, 2007 | 07:02 PM
awdgsx96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamonkey &raquo;</TD></TR><TR><TD CLASS="quote">1. If it was broken, would the vacuum still read??
Also, can a boost controller take the boost below the wastegate bar (.6)? In other words, can the boost controller take me lower than the 8.70 psi??</TD></TR></TABLE>
No. A controller's minimum level is determined by the wastegate spring
skuded
Apr 21, 2011 04:38 PM
turbo gsr2000
Aug 4, 2009 11:02 AM
Kamin
Sep 11, 2002 08:46 PM
ceemarun
Aug 27, 2002 04:00 PM
