BOGGING OUT / HESITATION PROBLEM ?
Old Sep 23, 2007 | 09:19 PM
00BoostedGSR's Avatar
Default BOGGING OUT / HESITATION PROBLEM ?
After racing my car a few times back to back it sort of boggs out/ hesitates on acceleration and dosnt respond well. But if I turn my car off, then immedatley turn it back on the problem goes away. What could be making my engine do that????????????????
Old Sep 23, 2007 | 09:30 PM
mtber's Avatar
Default Re: BOGGING OUT / HESITATION PROBLEM ? (00BoostedGSR)
Is your check engine light on or turning on when this occurs ?
If so, check your codes.
Regardless, get a wideband oxygen sensor asap.
Old Sep 23, 2007 | 09:41 PM
Default Re: BOGGING OUT / HESITATION PROBLEM ? (mtber)
my check engine light is always on because my O2 sensor is disconnected
Old Sep 23, 2007 | 09:59 PM
lambertincorp's Avatar
overheating?
Old Sep 24, 2007 | 03:09 PM
Default Re: BOGGING OUT / HESITATION PROBLEM ? (lambertincorp)
nope temp ,coolant and radiator is fine
Old Sep 24, 2007 | 03:39 PM
Brain3208's Avatar
Your throwing CEL's, you need to take care of that before you can diagnose this problem, your already running in open loop mode so your pig rich, fix up the o2 sensor so you can diagnose the next problem.
Old Sep 24, 2007 | 05:29 PM
Pman92's Avatar
Default Re: (Brain3208)
Yah cant run a honda without the factory 02 sensor hooked up. Car goes into limp mode. Hence the hessitation. To much gas.
Old Sep 24, 2007 | 06:28 PM
Default Re: (Pman92)
Now if I was going into limp mode, by me turning my engine off then immedataly on would that correct the problem, because when i do that everything is good?
civicpower94
Jul 30, 2005 08:40 PM
OriginalFive
Honda S2000
18
Jul 18, 2005 12:34 PM
Vega
Mar 7, 2005 07:32 AM
JohnnyLux
Oct 11, 2004 10:54 PM
