Turbo Cams?
Old Sep 24, 2007 | 05:15 AM
compuvision02's Avatar
Default Turbo Cams?
All I really have left for my motor is the head, I was thinking about doing Supertech valvetrain again, but I was a little stumped on camshafts. I might stick with the Type-R's, but I would rather go with a turbo camshaft, since the car is not dailied. Any opinions?
Old Sep 24, 2007 | 05:41 AM
Schister66's Avatar
Man U FTW
You have a few options. I would personally stick w/ the ITR or something fairly similar like the Blox Bs. Depending on how crazy you plan to get, you could look into MazWorx cams...i'm not sure entirely on whats available anymore
Old Sep 24, 2007 | 07:17 AM
morgan@synapse motorsport's Avatar
turbos cams seems to suck for hondas, typically the more aggressive all motor cams seem to do best. i would stick with the stock itr cams. i'm switching from gsr's to itr in my build soon.
Old Sep 24, 2007 | 08:26 AM
So there isn't anything that is going to get me any good gains versus Type-R camshafts? Driveability isn't that big of a deal, since it only drives on nice days, weekends, and to race. I just want to make as much power as I can.
Old Sep 24, 2007 | 08:43 AM
quicksilver1689's Avatar
i ♥ snails
tony had good gains going from type r's to skunk cams in his car like almost 100whp, but hes moving alot of air so your gains will be smaller, search for that thread. More power @ less boost is always good.
Old Sep 24, 2007 | 09:17 AM
AMR Engineering's Avatar
Default Re: Turbo Cams? (4F_Rob)
On my setup the best cams that I have used is the Rocket Motorsports M21 cam. I have yet to try it against a Skunk Pro 1. But the performance for the M21 won't dissappoint.
Old Sep 24, 2007 | 10:57 AM
boostfeen's Avatar
Default Re: (4F_Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4F_Rob &raquo;</TD></TR><TR><TD CLASS="quote">So there isn't anything that is going to get me any good gains versus Type-R camshafts? Driveability isn't that big of a deal, since it only drives on nice days, weekends, and to race. I just want to make as much power as I can.</TD></TR></TABLE>
..if you do some searching you will find that there are a few threads with some cam comparison tests. IMO, the best bang for your buck is CTR cams. If money is not an issue, then MazWorkx V1 cams, RM m21, or S2 Pro 1's are all very good choices that will out perform type R cams...also the bigger the setup(turbo/fuel) the more gains you will see.
Old Sep 24, 2007 | 01:48 PM
My setup is decent thus far, I just need to port the head before I get tuned. I would like to get different camshafts and do up the valvetrain too. I am aiming for around 600fwhp with just getting the head done.
Acura Integra LS (USDM DC2) B18B1 Block
Bored To 2.0L (81mm To 84mm)
Darton 84mm Sleeves
Darton Coolant Jacket
JE 9.0:1 Forged Pistons
Crower Rods
Honda Civic SiR-II (JDM EG6) B16A Head
Acura Integra Type-R (UDSM DC2) Valve Springs
ARP Head Studs
Acura Integra Type-R (USDM DC2) B18C Camshafts
Skunk2 Pro Series Intake Manifold
Acura Integra Type-R (UDSM DC2) Throttle Body
Full-Race Ram Horn Exhaust Manifold With VBand
Garrett GT35R 0.80 A/R Turbo
Tial 44mm Wastegate
Custom External Dumptube
Custom 2" and 3" Charge Pipes
Custom 3" Exhaust
Spearco 20x7.9x3.5 Intercooler
Greddy Type-S Blow Off Valve
Stainless Steel Lines
AEM Fuel Rail
RC 880cc Fuel Injectors
Walbro 255lph Fuel Pump
Fluidyne Radiator
Slim Fan
Old Sep 24, 2007 | 03:51 PM
880cc injectors arent gonna get you 600whp
Old Sep 24, 2007 | 05:49 PM
boostfeen's Avatar
Default Re: (mike@synapse motorsport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport &raquo;</TD></TR><TR><TD CLASS="quote">880cc injectors arent gonna get you 600whp</TD></TR></TABLE>
....yea, swap those out for some 1000cc injectors at least, and for comfort upgrade those valve springs and retainers for some higher revs, the cams are fine for 600hp. What are you using for managment?
Old Sep 24, 2007 | 05:55 PM
Turbo-charged's Avatar
on a customers car i made 590 on 880's but it started going lean. 570 or so AFR was still in check.....thats right around where we see walbro's take a crap too.
hold tight for a few days im doing a type R vs XXXX brand camshaft test starting tomarrow
Old Sep 24, 2007 | 09:43 PM
I plan on throwing 1000cc injectors in there before the tune.
I will be going on Neptune, right now it was just base tuned with a Romulator.
Old Sep 25, 2007 | 02:22 AM
taggart_lumpy's Avatar
from personal experience...
skunk2 turbo 1 &lt; 98 itr &lt; skunk2 pro 1
ill try and find exact figures again but if i recall it was about a 80hp diff between set 1 and 3
Old Sep 26, 2007 | 05:16 AM
I've been hearing good things about the Pro 1's, I may have to look into that.
Old Oct 3, 2007 | 04:59 AM
Any updates? The Pro 1's are looking good to me and I have around $1000 to spend, so I am thinking cams and tune!
Natural Aspirations
Jan 19, 2011 05:01 PM
Pompiuses
Nov 30, 2006 08:30 AM
ochsy03
Mar 10, 2005 08:15 AM
rocket256
Aug 25, 2003 09:04 PM
GoQkRaCeR
Feb 17, 2002 12:23 AM
