compression test results.....
Old Sep 28, 2007 | 08:13 AM
turbo-crx's Avatar
Default compression test results.....
stock b16 i got 180 across the board except #3 it was 120. it doesnt smoke, overheat, or blow smoke out the breather so im leaning toward headgasket issue since i can see it leaking out of one corner of the motor. any other ideas what it may be? stock b16 t3/t4 10 psi crome pro
Old Sep 28, 2007 | 08:18 AM
B18c1turboedEK's Avatar
Default Re: compression test results..... (turbo-crx)
Pour a cap of oil in there, redo compression test. If it goes up its the rings!
Old Sep 28, 2007 | 08:40 AM
turbo-crx's Avatar
Default Re: compression test results..... (B18c1turboedEK)
YEA I DID THAT. AT FIRST IT WAS 60 THEN SHOT TO 120. BUT WHAT I DONT UNDER STAND IS THAT IT DOESNT SMOKE OR ANY THING STILL HAS THE SAME POWER???????
Old Sep 28, 2007 | 02:40 PM
turbo-crx's Avatar
any body else have an idea?
Old Sep 28, 2007 | 02:45 PM
Turbo-charged's Avatar
the oil you are seeing is not from the headgasket. its coming from somewhere else and builds up at the corner of the head.
compression tests dont tell you very much other than something is wrong. do a leak down test and it will tell you the whole story, where the loss of compression is coming from.
Old Sep 28, 2007 | 03:40 PM
sc4dr's Avatar
Default Re: compression test results..... (Turbo-charged)
What do you know turbo-charged. get a real job
Old Sep 28, 2007 | 03:41 PM
urbansi's Avatar
Default Re: compression test results..... (sc4dr)
leak down test is key. also listen for air escaping out the IM and the exhaust
Old Sep 28, 2007 | 04:29 PM
Calvinator's Avatar
Default Re: compression test results..... (urbansi)
so the original test results where 180 180 60 180? then you put a cap of oil and it was 120? Sounds like rings are going out ot me, but like everyone else said, go do a leakdown test and let us know the results
Old Sep 29, 2007 | 09:22 PM
JaredKaragen's Avatar
Default Re: compression test results..... (Calvinator)
something tells me you have a faulty PCV or hose leading to... that tends to be the leanest cylinder because of the PCV. Any chance the cylinder's rings has an abnormal amount of buildup binding the rings? Let a bunch of seafoam soak in the cylinders overnight, then in the morning, fire it up, should help a little. your car will smoke out the neighborhood with the seafoam, but I use that **** to soak out and clean out the cylinders in motors that I am not rebuilding the bottom ends.
SilkyJohnson
13
Feb 15, 2011 05:54 PM
turbosivtec
May 24, 2009 04:33 PM
humboldt_skim
May 31, 2008 08:18 AM
Got_soy
28
Aug 8, 2005 12:49 PM
lazyguy
May 5, 2002 01:36 PM
