EGT gauge
Old Sep 24, 2007 | 05:14 AM
totsie7944's Avatar
Default EGT gauge
How necessary is the EGT gauge? I am currently getting ready to order...
Boost
Oil Pressure
Fuel Pressure
Oil Temp
Wideband
For cosmetic reasons of how I want the gauges displayed in the car, I'd rather not have a 6th gauge to mount somewhere.
Old Sep 24, 2007 | 06:30 AM
mike1114's Avatar
Default Re: EGT gauge (totsie7944)
no need for an EGT. The wideband basically replaces it. EGT tells you hot or not, the wideband tells you why your hot or not so basically the EGT is not needed.
Old Sep 24, 2007 | 06:59 AM
RedR's Avatar
Default Re: EGT gauge (mike1114)
the wideband won´t tell u if u r running too little timing or 2 much.
It is really not necessary, i personaly got one because this car is gonna see trackdays and some highway pulls i wanna keep an eye of when i gotta let off the gas before melting a piston
Old Sep 24, 2007 | 07:21 AM
totsie7944's Avatar
Default Re: EGT gauge (RedR)
true, but assuming you have a good tuner...and Ill have the best with Jeff Evans, an EGT, i assume would not really be needed.
I mean if theres that much risk of running lean or rich, maybe Ill get 1, but I just really have no where to put it without looking tacky haha
Old Sep 24, 2007 | 07:30 AM
stewie8apie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">true, but assuming you have a good tuner...and Ill have the best with Jeff Evans, an EGT, i assume would not really be needed.
I mean if theres that much risk of running lean or rich, maybe Ill get 1, but I just really have no where to put it without looking tacky haha</TD></TR></TABLE>
An EGT gauge is not necessary. Your wideband will tell you your afr's.
Old Sep 24, 2007 | 07:49 AM
dmotoguy's Avatar
Default Re: EGT gauge (stewie8apie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stewie8apie &raquo;</TD></TR><TR><TD CLASS="quote">
An EGT gauge is not necessary. Your wideband will tell you your afr's.</TD></TR></TABLE>
which has very little to do with what the EGT is telling you...
I agree they arent that necessary.. but not totally
Old Sep 24, 2007 | 10:03 AM
totsie7944's Avatar
Default Re: EGT gauge (dmotoguy)
well from what I'm reading, not many people get them. I think I'm going to skip on it at least for now.
Old Sep 24, 2007 | 10:10 AM
BoostedJeff's Avatar
Just get a wideband and call it a day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedR &raquo;</TD></TR><TR><TD CLASS="quote">the wideband won´t tell u if u r running too little timing or 2 much. </TD></TR></TABLE>
If you have a tuner that knows what he is doing, they can look at plugs and tell whats going on timing wise.
Old Sep 24, 2007 | 10:13 AM
totsie7944's Avatar
Default Re: EGT gauge (BoostedJeff)
sounds good man. Thanks.
Old Sep 24, 2007 | 12:29 PM
prelude2perfect's Avatar
sorry to thread jack, but is the fuel pressure gauge really necessary? I would think a water temp gauge would be more beneficial. I'm sure its great to have all gauges but it seams to me the top 5 to have would be boost, wideband, oil pressure, oil temp, and water temp. Am I wrong?
Old Sep 24, 2007 | 12:35 PM
InDub's Avatar
Default Re: EGT gauge (prelude2perfect)
Fuel press gauge is DEF necessary, at least a mechanical one in the engine bay for the dyno.
Stock water temp in cluster and use the ems to get exact reading
Wideband
Boost gauge
Done
Old Sep 24, 2007 | 01:59 PM
dirtySOHC's's Avatar
Default Re: EGT gauge (InDub)
i liked having an EGt gauge when i was doing highway pulls in 4th and 5th.
Old Sep 24, 2007 | 04:05 PM
Default Re: EGT gauge (dirtySOHC's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtySOHC’s &raquo;</TD></TR><TR><TD CLASS="quote">i liked having an EGt gauge when i was doing highway pulls in 4th and 5th.</TD></TR></TABLE>
lol, sounds safe
Old Sep 24, 2007 | 04:10 PM
totsie7944's Avatar
yea I would get it, but dont have the room. Id rather save a space for N20 one day lol hardcore rice baby
Old Sep 24, 2007 | 05:03 PM
dreadcivicturbo's Avatar
if you plan on doing highway top end runs...then get it.
Old Sep 24, 2007 | 05:22 PM
totsie7944's Avatar
Default Re: EGT gauge (dreadcivicturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreadcivicturbo &raquo;</TD></TR><TR><TD CLASS="quote">if you plan on doing highway top end runs...then get it.</TD></TR></TABLE>
why? When your tuner tunes the car they are doing 4th gear redline pulls for hours on end. Everyone I talk to keeps saying its not a necessity, just an addition.
Old Sep 24, 2007 | 05:39 PM
CivicVX94's Avatar
How much do EGT's and coolant temps correlate?
I figured that an EGT gauge is basically only for tuning and a coolant temp and wideband is all you need for the street...
Old Sep 24, 2007 | 07:28 PM
ham's Avatar
ham
Boost - must have
Oil Pressure - good to have
Fuel Pressure - no need, if your fuel pressure drops, your AF will show
Oil Temp - no need, if your coolant temps are good and low, your oil temps are good
Wideband - very important!
I only run 3 gauges in all my cars, never needed any more, never had any problems
Old Sep 25, 2007 | 04:53 AM
totsie7944's Avatar
Default Re: EGT gauge (ham)
From what I've read a lot of tuners recommend the fuel and oil pressure gauges.
Old Sep 25, 2007 | 02:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">
lol, sounds safe</TD></TR></TABLE>
super safe
Old Sep 25, 2007 | 02:19 PM
93supercoupe's Avatar
i think EGT's biggest advantage is when u have 4 probes and are triming each cylinder, but for anything under a race car, a good EMS will tell u everything u need know.
Old Sep 25, 2007 | 05:40 PM
blackeg's Avatar
Default Re: EGT gauge (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">i think EGT's biggest advantage is when u have 4 probes and are triming each cylinder, but for anything under a race car, a good EMS will tell u everything u need know.</TD></TR></TABLE>
yeah doesnt neptune have timing corrections for individual cylinder egt's?
this is why i want to get mine hooked up, just to keep an eye on things when i get into 5th.
i talked to jeff about the egt when he tuned my car, and i think he said its not really necessary
Old Sep 25, 2007 | 06:40 PM
CivicVX94's Avatar
Default Re: EGT gauge (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">this is why i want to get mine hooked up, just to keep an eye on things when i get into 5th.</TD></TR></TABLE>IMO when your boosting in 5th you probably shouldn't keep your eye on anything except the road
Old Sep 26, 2007 | 06:15 AM
totsie7944's Avatar
Default Re: EGT gauge (CivicVX94)
Jeff told me the EGT wasn't really necessary either so I'm not getting it...safest bet is always go with what your tuner tells you haha
Old Sep 26, 2007 | 04:01 PM
plain and simple...all you need is a boost gauge and wideband.
