tuning problem with plx300
Old Sep 30, 2007 | 01:07 AM
eg:R's Avatar
Default tuning problem with plx300
part-throttle tune my car with hondata s200b with plx300 wideband. the problem was that the a/f readings on the plx was difference to the readings on the hondata screen. also the plx wideband sitting was chosen on the hondata wideband sitting. which one should i get it tune to? the #'s are way off and dont come close to eachother
Old Sep 30, 2007 | 02:39 AM
SOHC_MShue's Avatar
Default Re: tuning problem with plx300 (eg:R)
always trust the wideband display over an analog output reading thats been interpreted by the program. You could have the settings in hondata wrong or some kind of grounding issue.
Old Oct 1, 2007 | 05:25 PM
eg:R's Avatar
hondata have a setting for wideband but it dont read the same. what gounding spots can i look for so i can get the readings alike.
Old Oct 1, 2007 | 06:00 PM
building boost's Avatar
Default Re: (eg:R)
slightly change the lambda conversion table values until the reading on the wideband and hondata display comes as close as you can get it.
fuel..
Engine Management and Tuning
Jan 8, 2012 08:20 PM
kornerk12
Jun 24, 2006 05:46 PM
Accord6Gen
Sep 6, 2004 08:29 AM
