YCP Vitara 75.5mm pistons - need help on piston/cylinder clearances!
Running a Greddy turbo kit on a 00 D16Y8 engine, will run 6 to 10 psi boost. I'm looking for piston to cylinder wall clearance specs for this application. Anybody running these with a similar setup and had good luck the a certain piston to cylinder wall clearance?
I've seen many threads out there that mention piston slap on the standard size pistons, so I'm going 20 over to eliminate this.
Thanks in advance for your input!
Redz_EX
05-14-2008 10:21 PM
seako_916
05-19-2004 08:52 PM
