Hooking up boost gauge need help.
Old Sep 30, 2007 | 11:48 AM
TurboEM1's Avatar
Default Hooking up boost gauge need help.
Autometer z series mechanical boost gauge. I need to tap that white nylon tubing into the boost/vac source. Where exactly does it go? I have the line going now then teed to the bov, then it continues then teed to the boost controller, then it goes into the wastegate.
Where do I want it?
Before the BOV? all the way at the end of the line?
Before Boost controller?
Before wastegate?
Thanks
Old Sep 30, 2007 | 12:25 PM
95jeremie's Avatar
Default Re: Hooking up boost gauge need help. (TurboEM1)
pick up a vac manifold for like 25-30 bucks
looks cleaner than having T's everywhere
one vac source for everything (break booster)
consistent vac source for everything
and now for your questions...
mount the vac manifold to your firewall
it will have it's own vac nipple off the manifold
makes life easy GL
Old Sep 30, 2007 | 12:28 PM
95jeremie's Avatar
Default Re: Hooking up boost gauge need help. (95jeremie)
https://honda-tech.com/zerothread/2111836
or mount it like this ...or whatever
i just feel that the firewall is the cleanest look
Old Sep 30, 2007 | 12:37 PM
TurboEM1's Avatar
I have a vacuum manifold. The thing is does that see boost and vacuum?
Anyway I just taped the gauge in between the fpr and the fuel rail.
Old Sep 30, 2007 | 01:09 PM
95teilhatch's Avatar
im about to hook my boost gauge up tomorrow. my directions got trashed but i think they said to hook it up at the vacuum line going to the BOV. not completly sure though. check the directions out.
if you have a vac manifold then do away with all the T'S. go straight to the manifold with your vacuum lines.
Old Sep 30, 2007 | 01:11 PM
Schister66's Avatar
Man U FTW
when i ran my boost gauge, i ran it off of the nipple that was originally for the FPR because i had run the FPR off of the vac manifold...
Just give it a vac source and forget about it...
Old Sep 30, 2007 | 01:13 PM
Default Re: (Schister66)
tru dat
AR_96
Sep 10, 2009 01:10 PM
CivicDude2k4
Jul 31, 2006 08:18 AM
R6E6I6D
Nov 24, 2005 04:36 PM
RNPoo7
Apr 8, 2005 06:33 AM
livinlow
Mar 15, 2005 09:21 PM
