B16 Boost Question
Old Sep 26, 2007 | 02:02 PM
Powelly's Avatar
Default B16 Boost Question
In the process of boosting my B16 and have been wondering how much psi i could run while maintaining reliability.
Compression :175psi across all cylinders
Wiseco low comp pistons
Eagle rods, ACL bearings, ARP nuts
ARP head studs, Cometic head gasket
Type R oil pump
RC 550's, AEM adj fpr
Skunk 2 valves & titanium retainers
standard valves, g.box, crank & cams
as for the turbo it's a t3/t4 a/r 0.50
Thanks
Tuning on S300 & Innovate wideband
Old Sep 26, 2007 | 02:08 PM
urbansi's Avatar
Default Re: B16 Boost Question (Powelly)
reliability is depent on how well the motor was put together and the tune to follow. the rest is up to you to make sure you dont beat the **** out of it constantly.
Old Sep 26, 2007 | 02:35 PM
ek_chris's Avatar
You can easily push 400whp on the motor (if your turbo setup allows). But like its been said, if you have a crap tuner and builder it won't last for very long whatsoever.
Old Sep 26, 2007 | 04:22 PM
Schister66's Avatar
Man U FTW
doesn't matter what kind of psi you run, but you're limited to what the stock sleeves will hold. there are a number of upper 400whp and low 500whp piston/rod combos
608_red_rex
Aug 12, 2009 09:39 PM
civicgeek133
Dec 4, 2006 02:29 PM
Samuels
Jun 30, 2006 03:48 PM
v63000gtv6
Jan 8, 2004 09:52 PM
Spooled1.6L
Jul 15, 2003 06:25 PM
