What parts would I need to prep a d15b for 300hp turbo setup?
What would be the list of parts I would be looking at getting? For making around 300-350 horsepower with a d15b
Re: What parts would I need to prep a d15b for 300hp turbo setup? (whole9)
I am talking internal engine parts btw. Everything outside of the engine I will have covered.
so all I need is some vitara pistons? and I am good to go for like 300-350 horsepower? thats amazing =] it says the fitment is a little off for the d15b unlike other d16's. anyway I guess all I would need is these pistons, and some better head bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF »</TD></TR><TR><TD CLASS="quote">you'll need to upgrade your rods also.</TD></TR></TABLE>
good luck even finding rods for a D15. i look for around a year for my setup at the time. no luck.
Re: What parts would I need to prep a d15b for 300hp turbo setup? (dxtosirex)
how long do you want to make 300hp for?
wideband, good tune
vitara, eagle h beam, upgrade your clutch
wideband, good tune
Re: What parts would I need to prep a d15b for 300hp turbo setup? (Crx dude)
why a d15? why not a d16? easier to find and rods are more readily available.
Re: What parts would I need to prep a d15b for 300hp turbo setup? (julioboostamante)
yea i want to make 300hp outta my d15b on a turbo set up too.....wanna no what im doin? gettin a d16z6 hahaha as much as i hate to say it there are practically NO PARTS for the internals of a d15 but if you have any luck findin the stuff u need lemme no ud save me a ton of money
Pirate General...YARRRR
Re: What parts would I need to prep a d15b for 300hp turbo setup? (dabigshmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabigshmo »</TD></TR><TR><TD CLASS="quote">yea i want to make 300hp outta my d15b on a turbo set up too.....wanna no what im doin? gettin a d16z6 hahaha as much as i hate to say it there are practically NO PARTS for the internals of a d15 but if you have any luck findin the stuff u need lemme no ud save me a ton of money</TD></TR></TABLE> wtf Ambler?
I grew up there
I lived in Butler park Condos as a youngin.
pm me I'm still semi local.
I grew up there
expletive that sucks, at least I can get the pistons for sure, someone, somebody, somewhere has to make rods and stuff for our engines!
Re: (whole9)
posts, vitaras, and forged rods are al you would need to be able to safely hit that goal, a stage II cam would make it easier depending on how small of a turbo you go with.
sell your d15 buy a b18c (gsr) get a t3/t4 hybrib turbo out of evo8 aem fuel rail walbro 255 fuel pump bosh 550cc injectors an a hondatta 2000 with good tuning. this is my setup for my integra. im doing 280hp @9psi dd. on stock motor
1 Post
Re: What parts would I need to prep a d15b for 300hp turbo setup? (confucioussae)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucioussae »</TD></TR><TR><TD CLASS="quote">head studs, injectors, fuel pump, MAP sensor, pistons, rods, rings, bearings, clutch...</TD></TR></TABLE>
he said 300hp not pushing 450hp haha... But good list though, im almost all the way through it...
Im about to do somewhat the same thing except im goin for 350, what turbine are you using?
1 Post
Re: What parts would I need to prep a d15b for 300hp turbo setup? (jdmjunkie8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjunkie8 »</TD></TR><TR><TD CLASS="quote">Im about to do somewhat the same thing except im goin for 350, what turbine are you using?</TD></TR></TABLE>
im at 218hp, on a t3t4 50 trim.. injectors, clutch, fuel pump, and some other small addon's.. and im only on 10psi... once my bottom end is built an i get MAP sensor i see no problem hittin 350hp...
