garrett .50 trim or .57 trim
building a turbo set up for my daily driver gsr and i was wondering witch turbo you guys think would be better for my set up. .63 exhaust housing. Not sure if the .50 trim will have better spool than the .57 trim, because that is what im leaning towards seening it is my daily. Will be using a log mani, tial 38mm wastegate, and a 2.5inch DP.
depends if you want room to grow or not. if not the get the smaller turbo for spool. if you do get the bigger one. if you only want 300-350 just get the 50 trim.
Re: garrett .50 trim or .57 trim (401tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner »</TD></TR><TR><TD CLASS="quote">building a turbo set up for my daily driver gsr and i was wondering witch turbo you guys think would be better for my set up. .63 exhaust housing. Not sure if the .50 trim will have better spool than the .57 trim, because that is what im leaning towards seening it is my daily. Will be using a log mani, tial 38mm wastegate, and a 2.5inch DP. </TD></TR></TABLE>
The 50 will spool sooner than the 57
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy »</TD></TR><TR><TD CLASS="quote">depends if you want room to grow or not. if not the get the smaller turbo for spool. if you do get the bigger one. if you only want 300-350 just get the 50 trim.</TD></TR></TABLE>
Re: garrett .50 trim or .57 trim (Autoworks)
.50 trim it is, will be ordering soon from greg at autoworks, great guy. Best service ive ever had on H-T.
Man U FTW
Either the 50 or 57 trim will be a good choice...you could split the difference with the GT3255b like i have. If i could do it over again, i'd error on the side of a turbo that's too small rather than too large. That's why i bought the turbo i bought
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">Either the 50 or 57 trim will be a good choice...you could split the difference with the GT3255b like i have. If i could do it over again, i'd error on the side of a turbo that's too small rather than too large. That's why i bought the turbo i bought</TD></TR></TABLE>
I wanted the GT32 but when I went to order it I was told they were backordered and didn't have a time when they would have them again. This was over 2 years ago though. I went with a SC34, basically the .57. I reach full boost (8 to 9psi) between 3500 and 4000. Setup is 3 inch dp, cl dump, high flow cat, and full 3 inch exhaust.
Man U FTW
I can't speak for two years ago, but i know that STC has GT32s on hand almost all the time now....you have a good turbo w/ that SC34 though.
What was the price of the SC34? The GT32? And who were you buying it through?
Re: (1158)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner »</TD></TR><TR><TD CLASS="quote">.50 trim it is, will be ordering soon from greg at autoworks, great guy. Best service ive ever had on H-T. </TD></TR></TABLE>
Thanks man, I appreciate it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">I can't speak for two years ago, but i know that STC has GT32s on hand almost all the time now....you have a good turbo w/ that SC34 though.
What was the price of the SC34? The GT32? And who were you buying it through?</TD></TR></TABLE>
I think I got the 34 for 650 or 680 brand new. I think the GT32 was a little more expensive, but not outrageously so. I bought it from wiredspeedlab, yeah...that's how long ago it was. I actually got it too!!! I'm very happy with the 34, but if anything were to happen, I probably would switch to the 32.
Re: (1158)
im not looking for big power at all because im trying to be reliable seeing i have high miles. Looking for under 300whp. But i plan on just using a chipped and socketed ecu with a basemap for my set up for now.
Re: (401tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner »</TD></TR><TR><TD CLASS="quote">im not looking for big power at all because im trying to be reliable seeing i have high miles. Looking for under 300whp. But i plan on just using a chipped and socketed ecu with a basemap for my set up for now.</TD></TR></TABLE>
The reliability is really in the tune, even on the low end of the boost spectrum. Have the basemap rechecked once it's on the car to double check the afr's once it is running for safety sake.
Yeah, all I wanted was around 300 and reliable. The tune is key. I don't have any experience with the .50, but from what I've read about it, I don't think you can make a wrong choice between the .50 or the .57.
Re: (401tuner)
nope dont have any videos. It was on a 17in DR and just basically spun through most of 3rd. i mean it was decently fast but i only got to enjoy it for 3 days till it cracked a sleeve...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">If you want dyno graphs of the GT3255 to compare to what the 50 trim should be, let me know and i'll toss it up here</TD></TR></TABLE>
I can add a graph of the SC34 (.57) with .63 A/R if you'd like. It was on a mustang dyno, but you can still compare the curves...
Greg is standup, you wont be disappointed.
50 trim>57 trim in every way, and it makes more power (flows more air). heres my setup, stock GSR with a 50 trim @ 10psi
Re: (methos713)
the .50 trim sounds good to me just because im looking for better spool time but im not sure how different it is between the 2
Re: (401tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner »</TD></TR><TR><TD CLASS="quote">the .50 trim sounds good to me just because im looking for better spool time but im not sure how different it is between the 2</TD></TR></TABLE>
It's a noticeable difference in spool time. The 50 will come in quite a bit earlier than the 57.
