Fuel pressure an Turbo cars...
I was talking with this guy last nite an he told me that I need t set my Fuel pressure accordingly. He said some thing like for lbs of boost you have to adjust you pressure or soem ****. idk what he was talking about. I kinda understand the fpr get will have positive pressure under boost but not understanding it.
Re: Fuel pressure an Turbo cars... (DrivinVtec)
As long as you have a vacuum/boost referenced regulator, you'll be fine. The most important part of the equation is proper tuning.
Base pressure should be near stock. You can use your stock regulator which is a 1:1 reference, which means that for every pound of boost the regulator sees, it'll raise fuel pressure by 1psi.
Re: (DrivinVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec »</TD></TR><TR><TD CLASS="quote">thanks. for my next question. are all honda fuel regs the same. i think i have a stock h23 one.</TD></TR></TABLE>
No...most are around 41-43 psi, some of the ITR and Accord (i think) are up to 50 psi
