Anyone pull just the motor and not the tranny for a swap?
I had a motor go bad in my DSM and pulled just the motor and left the tranny and everything attached in there and it was a bit of a strugle. Has anyone done this in a honda. Ive gotta pull my wounded B20 out and put my GSR in and looking for the quickest way to do it. So i thought id get some opinions on doin a swap with the tranny beinf left in the car.
Re: (Topdawgg)
So its easier to leave all the tranny stuff hooked up and just pull the motor? Ive done a ton of swaps but never this way, ive always pulled the whole drivetrain. The biggest problem i had doin it in the dsm was the input shaft on the tranny, it was a pain getting the motor pulled out because of clearing the input shaft.
Mr. Badwrench
Re: (tannerLSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt »</TD></TR><TR><TD CLASS="quote">leave the tranny in the car when doing a swap..... hahahahahha
how the hell is that easier</TD></TR></TABLE>
yeah really. on our cars it is really tight. how thick is the clutch assy? i could understand if it were an automatic, the flex plate is kinda thin, but, yeah i dont see how the hell you can get the engine out with the trans staying in the car. i used to split them and put them in separately, but dont see a need for that any more.
I can only imagine lining up the input shaft while the motor is on the lift. I've never done it this way (except in a dsm), but dsm's are a bit different. On hondas I always pull the whole drivetrain with it.
Re: (tannerLSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt »</TD></TR><TR><TD CLASS="quote">sounds like more of a pain in the ***. the tranny has to come off the motor either way. it takes what 10 minutes to take axles out... come on </TD></TR></TABLE>
Exactly, I have pulled and installed my fair amount of motors and I will always pull the whole deal (motor and tranny) out. It just seems so much easier in the long run.
Re: Anyone pull just the motor and not the tranny for a swap? (a1320honda)
that seems like it would be more trouble than its worth. Just pull everything.
ME LOVE U LONG TIME
i'm assuming since your gonna have the motor out you may replace the clutch, might as well throw a new throw-out bearing in... just take the whole thing out, and take the tranny off out of the car. much easier in my opinion.
Re: (tannerLSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt »</TD></TR><TR><TD CLASS="quote">i'm assuming since your gonna have the motor out you may replace the clutch, might as well throw a new throw-out bearing in... just take the whole thing out, and take the tranny off out of the car. much easier in my opinion. </TD></TR></TABLE>
No, its got a good clutch, just swapping the motor
Re: (a1320honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda »</TD></TR><TR><TD CLASS="quote">the input shaft</TD></TR></TABLE>
Thats the only thing I have probs with. I've spent more time lining that up or makign clearance for it in my life than I would have pulling the trans.
The plus is that you're forced to replace trans fluid, and given the right fluid - any slight grinds go away. I have a trans that ground in 2 & 3, now shifts perfect w/new Honda MTF. Too bad the bearings are FUBAR.
Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">I do it all the time with automatics. Not 5-speeds though, getting them back together is a pain.</TD></TR></TABLE>
its easier that way on the auto's like said above. if you drop the motor out of the bottom on a civic/integra it will def. take you longer to unbolt the trans.
Re: (Turbo-charged)
leave the trans conected and drop it through the bottom, u should have it on the ground in less than 2hrs.
Taking the trans off in the car is creating more work then u need to.
Mr. Badwrench
Re: (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">
its easier that way on the auto's like said above. if you drop the motor out of the bottom on a civic/integra it will def. take you longer to unbolt the trans.</TD></TR></TABLE>
i am now spoiled with lifts. i get laughed at when i say i drop them out the bottom.
Re: (bigbadboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe »</TD></TR><TR><TD CLASS="quote">leave the trans conected and drop it through the bottom, u should have it on the ground in less than 2hrs.
Taking the trans off in the car is creating more work then u need to.</TD></TR></TABLE>
either its not worth the trouble to take just the motor out. plus if it takes you more than 30-40 minutes to take the trans and motor out then you'll be there all day
jdmeg21
11
08-21-2009 03:34 AM
leprechan117
11
03-10-2003 04:03 PM
