valves? low compression..
Old Sep 23, 2007 | 04:03 PM
civic16's Avatar
Default valves? low compression..
ok, about a week ago i snapped a timing belt and the car jumped timing a lil, we put a new belt on it and did a compression test and it came out like this from 4 to 1
90 220 220 225. so i figured when i jumped timing i messed something up in the head. i took off the valve cover and did a compression test and it was like blowing smoke out of the exhaust valves on 4. so i got the head off and i cant tell whats wrong. any suggestions before i go any further??
Old Sep 23, 2007 | 04:22 PM
Garage 808 Hatch's Avatar
bent exhaust valves?
Old Sep 23, 2007 | 04:29 PM
civic16's Avatar
Default Re: (Garage 808 Hatch)
would it be pretty noticable thou? iv never had anything like this happen so i dont know exactly what to look for. wouldnt i notice a mark or something on the piston thou?
Old Sep 23, 2007 | 04:33 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (civic16)
put the head on a bench with some rags on the bench. keep the cams out, put hte head intake ports up. pour gas or mineral spirits on the port and see if it leaks. then do the same on the exh side.
Old Sep 23, 2007 | 04:37 PM
civic16's Avatar
Default Re: (boostedcivicsir)
did that, over time they slighty leaked i guess, like they were wet, not like puddles under or anything
Old Sep 23, 2007 | 05:46 PM
ferio82's Avatar
Default Re: valves? low compression.. (civic16)
did you give her a leakdown test yet. maybe that could help you out???
Wesleycrx
Dec 7, 2014 10:24 AM
Panoply
14
Jun 5, 2012 07:38 AM
lsv0892
Sep 7, 2011 09:56 AM
supabang
Jul 23, 2007 12:47 PM
Sisqo
Mar 10, 2006 05:54 AM
