b20 b
Old Dec 12, 2010 | 08:13 PM
B20integra24's Avatar
Default b20 b
hey guys im new to this site and to owning a honda....i been around the game and kno a good amount but when it gets technical im learning....i got a 95 teggy with a b20 b swap in it and it has a few probs i didnt see when i bought it.....needs a clutch and im replacing alot of gaskets and **** cause its a lil mess.....but i have a few questions like when im taking it outta gear to throw it in neutral sumtimes the idol drops to the point it stalls out on me.....it idles high cause i turned the idle up to try and prevent that but it didnt work...any ideas???....what clutch is streetable its my daily driver but is good for some abuse??.....im replacing the axle boots 2morro and shortly after the seal from the half shaft to the tranny cause thts broken but my other question is theres alot of oil built up on the altenator so do ou think it could be from a broken boot or what???if you guys could give me some advice oin everythign tht would be great thanx in advance
Old Dec 13, 2010 | 12:02 AM
Jimmy's Avatar
Global Moderator
Default Re: b20 b
I ran a chipped ecu on my old b20b swap, i actually fixed the same kind of problem (low idle) by adjusting my IAC compensation thru crome (running a chipped ecu) not sure if you are? & Yes.. if there's black grime on the alternator it is most likely axle grease, check the boots and replace as needed.
As far as clutches go.. ACT, Competition, EXEDY all brands.. Search the forum and read the [faq] about clutches.
check the Sponsor Marketplace for the best deals.
Old Dec 13, 2010 | 04:12 AM
Default Re: b20 b
Thank you for the help and advice......I did see on my way to work this morning that it wanted to stall a little bit more and I notice it does want to stall when I play with the gas pedel a little. it stalled and it took a couple seconds to crank over so I'm thinking possibly a fuel pump??.....I did buy the re-boot kit and I do need the seal where the half shaft meets the tranny so a lot of my undercarriage leaks are from the axles but the car does need distributor gasket and o-ring and a valve cover gasket also so that's what I believe is my upper leaks......I hope that I don't need an IAC they r pricey but I will try that 2 fix my crazy idle and stalling issues.....if you have any other possible ideas at issues or what to watch for that would be great.....and is a b20 b a usdm or jdm motor??
Old Dec 13, 2010 | 04:41 AM
lsturbo33's Avatar
Default Re: b20 b
Try to clean the iacv and reset the idle.
Old Dec 13, 2010 | 03:36 PM
Default Re: b20 b
Ok today took the IACV out and cleaner it and had 2 re-wire the wires 2 it because previous owner was terrible at working on cars.....I cleaned it out and it still is having a hard time idling and on the way home from work almost everytime I put my foot on the clutch it would almost stall unless I put it in gear or rev-ved it a little....I'm thinking its a tps and as far as every once and a while when it takes a while 2 start after it stalls idk what that is?.....its annoying trying 2 drive the car with it stalling like it is and it doesn't make it easier that the clutch is going and to start out I have to put it in 1st before I stop or it won't go into gear.....someone please help!!!
corps
10
Jun 17, 2009 02:42 PM
93eg2james
48
Dec 22, 2006 01:46 PM
sinolimitssi
Mar 24, 2005 05:20 PM
Jammersplace
Jul 17, 2004 03:42 PM
